Both radios are showing solid green lights? I’ve been using these exclusively with Pixhawk 2.1 for several months including 3.8. If you’ve got solid green on both I’ll take a look when I get to the hangar in the morning.
That confirms that at least the two radios are definitely communication with each other. Are you using a cable for the Pixhawk 2 that you put together yourself? If so,have you validated the pin order and that the Rx and Tx pins have continuity on both ends? Here’s a diagram in case that “might” be an issue. Ignore the power and ground if you have it different but the others are what I’d check.
I have a RFD 900 (note, not a 900+ but I don’t think that matters) with a cable as @Todd_Bagley shows in the diagram and it works correctly on a PixHawk 2.1. (Thanks for that Todd_Bagley!)
I’m having the same exact issue. This occurred the moment I upgraded to 3.8 and upgraded to latest Mission Planner. I haven’t been an able to find a solution. I had to downgrade to 3.7 again.
@Todd_Bagley : yes, put together cable. I’ll double check. We have a jumper between #4 and #6. Not a BEC for #2 and #4. That same wiring works with Pixhawk1 though (different cables though).
@hunt0r : ArduPlane? ArduPlane? which version? Could you provide your param file or the SERIAL1_* , SR1_* , and SER1_* parameters you use please? Thanks
I have it working right now with a PixHawk 2.1, ArduPlane 3.8.0, Mission Planner 1.3.49, RFD 900’s on both GCS and PH. (note: not RFD 900+… in case that’s the difference?)
I’m using firmware 1.9 on my RFD’s. (I think it’s outdated, but it works.) So @Alexander_Perez do I understand correctly that for everything else held constant (same MP version, Firmware version, Pixhawk, same cable, etc.), your RFD’s work for ArduPlane 3.7 but not for ArduPlane 3.8?
Thanks Todd making this diagram!
Here is one additional image which shows how ready made cables are put together. I made this referring images online and without physical cable in hands.
AP + = RFD900 pin 5
AP - = RFD900 pin 1
With this connection radio modem is powered from Pixhawk (Image from RFDesign documentation):
