Is there a way to connect one copter to 2 or more ground control stations at the same time, so do terminals can see the telemetry information of the craft? I draw something to depict my question
The RFD900 Multipoint firmware will do that: https://files.rfdesign.com.au/Files/documents/RFD900x%20Multipoint%20User%20Manual%20V1.1.pdf
If your GCSs are closer enough from each other, you can use MAVLink Forwarding to access information in a Local Network topology also.
