Reverse channel input - set in parameter list has no effect (do not reverse)
(Peter Weichhart) #1
As in my Topic described: I reversed in the parameter list the channel input of (e.g. channel 2+3 to reverse)
After restart of the controller (Pixhawk 2.1 Cube), it has no effect. The channel is not reversed!
Any idea what I am doing wrong?
(Amilcar Lucas) #2
What FW version are you using? What RC protocol, how is it connected?
(Peter Weichhart) #3
I am using Mission Planner 1.3.66 with the following FW:
It is connected as following: Joystick (PWM) is going into a PWM to PPM Signal Converter. From the Signal converter the PPM Signal is going into the Pixhawk 2,1. All is working fine in Radio Setup (also the two channels which I like to reverse). Also the calibration was successful. Min and Max is fine, just the reverse is not working.
I hope I got your questions and answered all of them
(Peter Weichhart) #4
What ever I am trying: Still the same! I am running now firmware 3.6.9 but same problem
(...) #5
Why not just reverse the channel at the transmitter?
(Peter Weichhart) #6
Because my RC do not have this function (It is a self made one)
(Peter Hall) #7
how are you testing?, the green bar things on MP radio input page seem to sometimes ignore the reverse parameters
(Peter Weichhart) #8
I am testing with the green bars in MP. I will check it tonight. Thanks
(Peter Weichhart) #9
Seems like you are right. Because I have another issue posted regarding the arming process. Instead of arming it starts compass calibration. But of course it is doing it because I move the throttle in the wrong direction (because I thought it is not reversed. I will confirm in the evening, but I am 99,9% sure the problem is solved. Thank you so much
(Peter Hall) #10
np, first think would be to update mission planer, next try with QGC
(Peter Weichhart) #11
Thanks Peter! You are right. Solved with your advice!!! Thank you so much!!!
