Hello
I am trying to extract the rc values coming from mavlink using dronekit. To test my code I am running sim_vehicle.py in one terminal, while in other I connect my script with the command --connect udp:127.0.0.1:14550.
The code is simple, I use vehicle.channels to retrieve information but all I get is None. I also tried add a message listener to get the values, but it didn’t solve either.
import time
import argparse
import dronekit
parser = argparse.ArgumentParser(description='Commands vehicle using vehicle.simple_goto.')
parser.add_argument('--connect', help="Vehicle connection target string. If not specified, SITL automatically started and used.")
args = parser.parse_args()
connection_string = args.connect
vehicle = dronekit.connect(connection_string, wait_ready=True
while True:
print(vehicle.channels)
time.sleep(2)
