Hi, we are using Pixhawk 2 with Tricopter platform drones.
However while we are performing mission with survey grid navigation, we get the test to change the flight mode to Loiter to move out from the navigation but, after the resume the mission, the drone went to next way point directly so, the photographs for survey could not completed. Is there any command let the drone start over from last way point when operator resume the mission? We are using GCS as mission planner. (What if it is capable via QGroundControl, please let me know.)
Thanks for your comment. During the checking the command, within flight data screen of Mission Planner, we could not found the command with right click unfortunately. However, instead of it, we found the following one in action tab. Could you advise me that the menu can be act as command regarding to Waypoint? as you advised?
The command in the Action tab was the one I was referring to.
In APM Planner its called ‘go to waypoint’ in Mission Planner as you found it is “set WP”
