Reset EKF Origin using mavlink without a reboot
Is it possible to reset the EKF origin using mavlink without rebooting the FC?
Thanks
Hi @StrikeEagle,
No, I’m afraid that once the EKF origin is set, it can’t be moved.
If the aim is to reset the vehicle’s position to a known correct position when using non-GPS then I did create a PR to do that but it hasn’t been merged due to a similar PR appearing at the same time and the other PR won. We could revisit this..
My aim was to really reset the EKF rogifin because I want to use local NED.
I currently ended up with rebooting the vehicle via pymavlink if the drone has moved, say about 30 cm, from the current origin along either the X or y axes and then set the EKF again.
Regardless, that PR seems useful.
