Release Rover-4.4 as stable OK?
I’m thinking about releasing Rover-4.4.0 as the stable stable. Although I think there are still some questions around L1 vs SCurves but I think we need to move forward and try and improve SCurves in subsequent releases.
What’s given me additional confidence recently is that I tested a BlueRobotics BlueBoat which was running 4.2 but then simply upgraded to 4.4 with no additional parameter changes and it worked great.
I’m interested to hear other opinions on this though.
I upgraded my boogie board from 4.2 to the latest dev version to test the autotune and had zero issues with that update. I am not the best person to give feedback but don’t think it would be a big deal plus it would be nice to try and keep releases even across platforms
Have you and Leonard resolved the WP radius/timing issue? That’s the only blocker I see. Otherwise, there are a ton of improvements that are otherwise lost by not releasing.
No issues with 4.4 on my rovers.
SCurves and the (related?) WP radius issues would make any waypoint navigation a bit of an issue - I’m hoping to assist with this in the coming months, now that it’s getting warmer outside!
I’d agree that it’s important to keep the rover synchronised with copter/plane releases as much as possible. It’s getting to the point where I’ve got clients running off a master on their vehicles, so they can get the latest features.
My yard has essentially died in the insane heat wave this summer, so my mowing has been limited to non-existent. I have an upcoming build with electric motors that I hope to use as a contrast to the hydrostatic drives on my primary mower that has become a workhorse test bed for Rover features. I’m eager for the heat to break, too, so I can be a little more productive!
Hi @Yuri_Rage,
Thanks for the reminder on the waypoint radius issue. I have put some time into this and the current status is that I see the same issue in Copter in SITL at least so I’m planning to discuss with @Leonardthall again.
I think there is still an issue. RCINxScaled works now in 4.4 beta7 but not correct.
When setting in Missionplanner/Setup/Mandatory Hardware/Servo Output:
Function = RCINxScaled then the full Range of PPM works only when the Trim is set to the min Value.
E.g. min= 900 Trim = 900 max = 2100.
When Trim is set to 1500 the min is not reached in the Output.
This means, it does not work as discribed in the Wiki.
Hi @Lorbass1,
Thanks for the report. If you’ve got a .bin log that would be great but in any case I’ll try and test myself.
Thanks for the reply. Sorry, I forgott you need facts.
Here in the pic to see: 1. With “assymetrical” Trim. 2. With Trim as usual. 3. Again with Trim at min Value
And here the link to the .bin File
(Strange Link-Text, I released the file for everybody)
I’m shure you will find the small bug. :wink:
