I’m currently working on getting relay’s working with my orange cube+
I have 3 relays I need to actuate from the controller that aren’t cooperating correctly. I can actuate all 3 of them just fine, but I cannot turn them off.
This is odd because previously I could turn them on and off no problem, but then without changing anything, they stopped turning the relays off.
They are solid state relays.
I have the RCx_option corresponding correctly to relays 1/2/3 on/off
I have the channels on main pins 4, 5, and 6.
I have 4, 5, and 6, set as GPIO
I have the main pins BRD_PWM_VOLT_SEL as 5V
relayx_pin set to 104, 105, 106
When i go through and disable the servo outputs, it disables the relays.
To add, these are on the main outputs and not the AUX because when they were on AUX I was getting an output of only 2V at maximum and I need at least 3.3V to actuate my relays. When on the main outputs I get a good 4.5V.
The relay toggles on the mission planner do not work (they did previously)
When actuated I do get the appropriate message saying:
6/14/2024 10:53:32 AM : RC11: Relay3 LOW
6/14/2024 10:53:30 AM : RC11: Relay3 HIGH
any help is appreciated
