I use on my plane with Arduplane 4.4 alternatively both ELRS 2.4G or Crossfire receivers.
Control works fine and I’m getting also RSSI and LQ readings for my OSD and logfiles, but especially LQ readings are very suspect to me.
It seems to be too much similar to RSSI as it’s unnatural (of course, if they are set to the same scale.)
This is not normal, typically RSSI is going down with the distance with full LQ and LQ starts having drops much later, when RSSI gets really low.
Can someone check his logfiles and confirm or refuse my observation?
It seems that LQ value is a copy of RSSI and not real LQ.
(Image was created with overlaying screenshots from RSSI and LQ from the same log. I couldn’t do it directly because they use different scale (0-1 against 0-100).)
