Hi, I’m about to make a driver for a SPI device.
I’m using a pixracer board and as a test I tried to read the device id (whoami
) of the mpu9250.
The read_registers()
operation goes fine but the value read is wrong.
The value of the whoami
register should be 0x71, but i get 0x00.
Can you tell me if there’s something wrong in the following code?
(I write it looking at AP_InertialSensor)
AP_HAL::OwnPtr<AP_HAL::SPIDevice> _dev;
uint8_t *_buffer;
_dev = hal.spi->get_device("mpu9250");
if (!_dev) {
hal.console->printf("DEV NOT FOUND");
return;
_dev->set_read_flag(0x80);
if (!_dev->get_semaphore()->take(HAL_SEMAPHORE_BLOCK_FOREVER)) {
hal.console->printf("SEMAPHORE ERROR");
return;
_dev->setup_checked_registers(7, 20);
_dev->set_speed(AP_HAL::Device::SPEED_LOW);
// random value because it reads 0 and wanted to be sure that it was the read to set it to 0
uint8_t id = 42;
// 0x75 = whoami reg addr
if(_dev->read_registers(0x75, _buffer, 1)){
id = *_buffer;
hal.console->printf("REGISTER READ");
else{
hal.console->printf("READ ERROR");
_dev->get_semaphore()->give();
return;
if(id == 0x71){ // 0x71 = default whoami reg value
hal.console->printf("ID CHECKED \n ID = %02x", id);
else{
hal.console->printf("ID ERROR \n ID = %02x", id);
return;
Thank you!
