I’ve been trying to get the code in AP_HAL/examples/RCOut.cpp to output a PWM command to a servo on any channel on my Pixhawk4 (px4-v2) and failed so far. The servo moves in one direction by some amount but doesn’t move back as should happen in the example code (it moves only when I plug in the battery, so it seems it’s just a startup transient).
I believe my issue is with arming/turning off the output safety flags for the board, so I’ve modified the code slightly in an attempt to do this. I’m not using a physical safety switch and want to be able to enable servo outputs.
I’ve powered the servo rail using a BEC, and with Copter 3.6 loaded I am able to get the servo to respond in Mission Planner using the servo toggle functions (even without arming the board using a switch or turning off the arm checks in config/tuning).
What am I missing? So far while learning the code, simply running the examples without change has worked,but not this time.
Here’s my modified code (note the basic example doesn’t work):
simple test of RC output interface
#include <AP_HAL/AP_HAL.h>
#include <AP_HAL/RCOutput.h>
#include <AP_BoardConfig/AP_BoardConfig.h>
#include <AP_Param/AP_Param.h>
//#include <AP_HAL_PX4/RCOutput.h>
// Just so that it’s completely clear…
#define ENABLED 1
#define DISABLED 0
// this avoids a very common config error
#define ENABLE ENABLED
#define DISABLE DISABLED
AP_BoardConfig BoardConfig;
void setup();
void loop();
const AP_HAL::HAL& hal = AP_HAL::get_HAL();
void setup (void)
hal.console->printf("Starting AP_HAL::RCOutput test\n");
for (uint8_t i = 0; i< 14; i++) {
hal.rcout->enable_ch(i);
hal.console->printf("Enable Channel %u \n", i);
hal.rcout->force_safety_off();
//Change parameters for board
float SET_PWM_PARAMETER = 14;
AP_Param::set_object_value(&BoardConfig, BoardConfig.var_info, "PWM_COUNT", SET_PWM_PARAMETER);
AP_Param::set_object_value(&BoardConfig, BoardConfig.var_info, "SAFETYENABLE", DISABLE);
AP_Param::set_object_value(&BoardConfig, BoardConfig.var_info, "SAFETYOPTION", 0);// 0 1 2
AP_Param::set_object_value(&BoardConfig, BoardConfig.var_info, "SAFETY_MASK", 8191);
static uint16_t pwm = 1500;
static int8_t delta = 1;
void loop (void)
for (uint8_t i=0; i < 14; i++) {
hal.rcout->enable_ch(i); //ADDED
hal.console->printf("Enabled Channel %u \n", i);
hal.rcout->write(i, pwm); //ONLY CHANNEL 2; (uint8_t)2
pwm += delta;
hal.console->printf("Driving Channel %u at %u Hz and PWM %u, last sent %u, read output value: %u\n",
i,
hal.rcout->get_freq(i),
pwm,
hal.rcout->read_last_sent(i),
hal.rcout->read(i));
hal.console->printf("Enabled PWMs: %u, Safety Mask: %u, IO Enable: %u \n",
BoardConfig.get_pwm_count(),
BoardConfig.get_safety_mask(),
BoardConfig.io_enabled());
if (delta > 0 && pwm >= 1900) { //ORIGINALLY 2000
delta = -1;
hal.console->printf("Reversing Channel %u at %u Hz and PWM %u\n", i, hal.rcout->get_freq(i),pwm);
hal.scheduler->delay(1000); //was 5
} else if (delta < 0 && pwm <= 1100) { //ORIGINALLY 1000
delta = 1;
hal.console->printf("Normalizing Channel %u at %u Hz and PWM %u\n", i, hal.rcout->get_freq(i),pwm);
hal.scheduler->delay(100); //was 5
AP_HAL_MAIN();
