Rc in/override - mavros
hi i try to do some operation with mavros ros2
hardware - i am connect telem 433 of holybro to linux computer with joystick and try to run this node and script(add at the end):
  1. mavros node:
    ros2 run mavros mavros_node --ros-args -p fcu_url:=/dev/ttyUSB0:57600 -p gcs_url:=udp://@192.168.1.142:14550 -p sysid:=1
  2. joy node
    3)script (at the end)
i try with another widows computer to connect via udp and check if i get radio at the radio calibartion and i dont get any information
i try to run this script at px4 with sitl and get data about the controller
the script:
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Joy
from mavros_msgs.msg import OverrideRCIn  # Ensure this is the correct message type
import time
class RCOverrideNode(Node):
    def __init__(self):
        super().__init__('rc_override_node')
        self.publisher_ = self.create_publisher(OverrideRCIn, '/mavros/rc/override', 10)  # Update the publisher to OverrideRCIn
        self.joy_subscription = self.create_subscription(
            Joy,
            '/joy',
            self.joy_callback,
            10
        self.joy_subscription  # prevent unused variable warning
        # Call reset_parameters once at startup
        self.reset_parameters()
    def reset_parameters(self):
        # Set all channels to 65535 at the start to indicate no override
        rc_override = OverrideRCIn()
        rc_override.channels = [65535] * 12  # Assuming 12 channels
        self.publisher_.publish(rc_override)
        self.get_logger().info('RC Override parameters reset to 65535')
        time.sleep(2)
        rc_override.channels = [0] * 12  # Assuming 12 channels
        self.get_logger().info('RC Override parameters reset to 0')
    def joy_callback(self, msg):
        rc_override = OverrideRCIn()  # Create an instance of OverrideRCIn
        # Map joystick axes/buttons to RC channels
            self.scale_value(msg.axes[0], -1.0, 1.0, 1000, 2000),  # Roll (Ch1)
            self.scale_value(msg.axes[1], -1.0, 1.0, 1000, 2000),  # Pitch (Ch2)
            self.scale_value(msg.axes[2], -1.0, 1.0, 1000, 2000),  # Throttle (Ch3)
            self.scale_value(msg.axes[3], -1.0, 1.0, 1000, 2000)   # Yaw (Ch4)
        # Debug statements
        self.get_logger().info(f'Joy axes: {msg.axes}')
        self.get_logger().info(f'RC Override: {rc_override.channels}')
        # Publish the RC override message
    @staticmethod
    def scale_value(value, src_min, src_max, dst_min, dst_max):
        # Scale value from source range to destination range
        src_range = src_max - src_min
        dst_range = dst_max - dst_min
        scaled_value = ((value - src_min) * dst_range) / src_range + dst_min
        return int(scaled_value)
def main(args=None):
    rclpy.init(args=args)
    node = RCOverrideNode()
    rclpy.spin(node)
    node.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
i think i got some problem with the callibration of my fc
thanks for the help
