Hi, just a suggestion. The link
says:
Connecting and Configuring the Lidar
follow the normal instructions for setting up rangefinders.
set the RNGFNDx_ORIENT parameters (i.e. RNGFND_ORIENT, RNGFND2_ORIENT) to specify the direction the range finder is pointing in (i.e. 0=Forward, 2=Right, 4=Back, 6=Left, 24=Up, 25=Down)
set PRX_TYPE = “4” to enable using range finders as “proximity sensors”.
set AVOID_ENABLE to “7” to enable avoidance using proximity sensors (and fences)
Rngfnd_orient only works for downwards with leddarone.
Prx_type works perfect with 0(none) with leddarone. Option 4 will say lidar unhealthy or check proximity sensor
Avoid_enable to 7 is not possible in ac 3.5.3. Only 3 (all) is possible.
Thanks in advance
