Matek F405-SE with Copter 4.5.0-beta2, EdgeTX 2.9.3
EDIT: I just tried the same combination (Plane 4.5.0-beta2 + CRSF 6.19) on an F405-WING, and Yaapu was working instantly. Both FCs are using F405-WING target, so I guess that makes the whole thing even weirder.
ACRO_BAL_PITCH,1
ACRO_BAL_ROLL,1
ACRO_OPTIONS,1
ACRO_RP_EXPO,0.3
ACRO_RP_RATE,360
ACRO_RP_RATE_TC,0
ACRO_THR_MID,0
ACRO_TRAINER,2
ACRO_Y_EXPO,0
ACRO_Y_RATE,157.5
ACRO_Y_RATE_TC,0
AHRS_COMP_BETA,0.1
AHRS_EKF_TYPE,3
AHRS_GPS_GAIN,1
AHRS_GPS_MINSATS,6
AHRS_GPS_USE,1
AHRS_OPTIONS,0
AHRS_ORIENTATION,0
AHRS_RP_P,0.2
AHRS_TRIM_X,-0.010077
AHRS_TRIM_Y,-0.0244371
AHRS_TRIM_Z,0
AHRS_WIND_MAX,0
AHRS_YAW_P,0.2
ANGLE_MAX,6500
ARMING_ACCTHRESH,0.75
ARMING_CHECK,1048058
ARMING_MAGTHRESH,100
ARMING_MIS_ITEMS,0
ARMING_OPTIONS,0
ARMING_RUDDER,0
ATC_ACCEL_P_MAX,332240.1
ATC_ACCEL_R_MAX,386442
ATC_ACCEL_Y_MAX,74182.25
ATC_ANG_LIM_TC,1
ATC_ANG_PIT_P,27.21886
ATC_ANG_RLL_P,28.8674
ATC_ANG_YAW_P,13.60845
ATC_ANGLE_BOOST,1
ATC_INPUT_TC,0.15
ATC_RAT_PIT_D,0.0013291
ATC_RAT_PIT_D_FF,0
ATC_RAT_PIT_FF,0
ATC_RAT_PIT_FLTD,37.5
ATC_RAT_PIT_FLTE,0
ATC_RAT_PIT_FLTT,37.5
ATC_RAT_PIT_I,0.0830718
ATC_RAT_PIT_IMAX,0.5
ATC_RAT_PIT_P,0.0830718
ATC_RAT_PIT_PDMX,0
ATC_RAT_PIT_SMAX,0
ATC_RAT_RLL_D,0.001
ATC_RAT_RLL_D_FF,0
ATC_RAT_RLL_FF,0
ATC_RAT_RLL_FLTD,37.5
ATC_RAT_RLL_FLTE,0
ATC_RAT_RLL_FLTT,37.5
ATC_RAT_RLL_I,0.0633212
ATC_RAT_RLL_IMAX,0.5
ATC_RAT_RLL_P,0.0633212
ATC_RAT_RLL_PDMX,0
ATC_RAT_RLL_SMAX,0
ATC_RAT_YAW_D,0
ATC_RAT_YAW_D_FF,0
ATC_RAT_YAW_FF,0
ATC_RAT_YAW_FLTD,19
ATC_RAT_YAW_FLTE,2.420868
ATC_RAT_YAW_FLTT,37.5
ATC_RAT_YAW_I,0.0233197
ATC_RAT_YAW_IMAX,0.5
ATC_RAT_YAW_P,0.2331973
ATC_RAT_YAW_PDMX,0
ATC_RAT_YAW_SMAX,0
ATC_RATE_FF_ENAB,1
ATC_RATE_P_MAX,0
ATC_RATE_R_MAX,0
ATC_RATE_Y_MAX,0
ATC_SLEW_YAW,6000
ATC_THR_G_BOOST,0
ATC_THR_MIX_MAN,0.5
ATC_THR_MIX_MAX,0.5
ATC_THR_MIX_MIN,0.1
AUTO_OPTIONS,0
AUTOTUNE_AGGR,0.075
AUTOTUNE_AXES,7
AUTOTUNE_MIN_D,0.001
AVOID_ACCEL_MAX,3
AVOID_ALT_MIN,0
AVOID_ANGLE_MAX,1000
AVOID_BACKUP_DZ,0.1
AVOID_BACKUP_SPD,0.75
AVOID_BEHAVE,0
AVOID_DIST_MAX,5
AVOID_ENABLE,3
AVOID_MARGIN,2
BARO_ALT_OFFSET,0
BARO_ALTERR_MAX,2000
BARO_EXT_BUS,-1
BARO_FLTR_RNG,0
BARO_GND_TEMP,0
BARO_OPTIONS,0
BARO_PRIMARY,0
BARO_PROBE_EXT,0
BARO1_DEVID,423425
BARO1_GND_PRESS,101782.8
BARO2_DEVID,0
BARO2_GND_PRESS,0
BARO3_DEVID,0
BARO3_GND_PRESS,0
BATT_AMP_OFFSET,0
BATT_AMP_PERVLT,55.9
BATT_ARM_MAH,0
BATT_ARM_VOLT,21
BATT_CAPACITY,1550
BATT_CRT_MAH,0
BATT_CRT_VOLT,19
BATT_CURR_PIN,11
BATT_FS_CRT_ACT,1
BATT_FS_LOW_ACT,0
BATT_FS_VOLTSRC,0
BATT_LOW_MAH,0
BATT_LOW_TIMER,10
BATT_LOW_VOLT,21
BATT_MONITOR,4
BATT_OPTIONS,0
BATT_SERIAL_NUM,-1
BATT_VLT_OFFSET,0
BATT_VOLT_MULT,11
BATT_VOLT_PIN,10
BATT2_MONITOR,0
BATT3_MONITOR,0
BATT4_MONITOR,0
BATT5_MONITOR,0
BATT6_MONITOR,0
BATT7_MONITOR,0
BATT8_MONITOR,0
BATT9_MONITOR,0
BRD_ALT_CONFIG,0
BRD_BOOT_DELAY,0
BRD_OPTIONS,1
BRD_RTC_TYPES,1
BRD_RTC_TZ_MIN,0
BRD_SAFETY_DEFLT,0
BRD_SAFETY_MASK,16368
BRD_SAFETYOPTION,3
BRD_SD_SLOWDOWN,0
BRD_SERIAL_NUM,0
CAM_AUTO_ONLY,0
CAM_MAX_ROLL,0
CAM1_TYPE,0
CAM2_TYPE,0
CIRCLE_OPTIONS,1
CIRCLE_RADIUS,1000
CIRCLE_RATE,20
COMPASS_AUTO_ROT,2
COMPASS_AUTODEC,1
COMPASS_CAL_FIT,16
COMPASS_DEC,0
COMPASS_DEV_ID,466441
COMPASS_DEV_ID2,0
COMPASS_DEV_ID3,0
COMPASS_DEV_ID4,0
COMPASS_DEV_ID5,0
COMPASS_DEV_ID6,0
COMPASS_DEV_ID7,0
COMPASS_DEV_ID8,0
COMPASS_DIA_X,0.8948504
COMPASS_DIA_Y,0.9043008
COMPASS_DIA_Z,1.109321
COMPASS_DIA2_X,1
COMPASS_DIA2_Y,1
COMPASS_DIA2_Z,1
COMPASS_DIA3_X,1
COMPASS_DIA3_Y,1
COMPASS_DIA3_Z,1
COMPASS_DISBLMSK,0
COMPASS_ENABLE,0
COMPASS_EXTERN2,0
COMPASS_EXTERN3,0
COMPASS_EXTERNAL,0
COMPASS_FLTR_RNG,0
COMPASS_LEARN,0
COMPASS_MOT_X,0
COMPASS_MOT_Y,0
COMPASS_MOT_Z,0
COMPASS_MOT2_X,0
COMPASS_MOT2_Y,0
COMPASS_MOT2_Z,0
COMPASS_MOT3_X,0
COMPASS_MOT3_Y,0
COMPASS_MOT3_Z,0
COMPASS_MOTCT,0
COMPASS_ODI_X,-0.0147427
COMPASS_ODI_Y,-0.0085109
COMPASS_ODI_Z,0.0068992
COMPASS_ODI2_X,0
COMPASS_ODI2_Y,0
COMPASS_ODI2_Z,0
COMPASS_ODI3_X,0
COMPASS_ODI3_Y,0
COMPASS_ODI3_Z,0
COMPASS_OFFS_MAX,1800
COMPASS_OFS_X,40.43876
COMPASS_OFS_Y,34.98051
COMPASS_OFS_Z,58.99296
COMPASS_OFS2_X,0
COMPASS_OFS2_Y,0
COMPASS_OFS2_Z,0
COMPASS_OFS3_X,0
COMPASS_OFS3_Y,0
COMPASS_OFS3_Z,0
COMPASS_OPTIONS,0
COMPASS_ORIENT,0
COMPASS_ORIENT2,0
COMPASS_ORIENT3,0
COMPASS_PMOT_EN,0
COMPASS_PRIO1_ID,466441
COMPASS_PRIO2_ID,0
COMPASS_PRIO3_ID,0
COMPASS_SCALE,0
COMPASS_SCALE2,0
COMPASS_SCALE3,0
COMPASS_USE,0
COMPASS_USE2,1
COMPASS_USE3,1
CUST_ROT_ENABLE,0
DEV_OPTIONS,0
DISARM_DELAY,10
EK3_ABIAS_P_NSE,0.02
EK3_ACC_BIAS_LIM,1
EK3_ACC_P_NSE,0.35
EK3_AFFINITY,0
EK3_ALT_M_NSE,2
EK3_BCN_DELAY,50
EK3_BCN_I_GTE,500
EK3_BCN_M_NSE,1
EK3_BETA_MASK,0
EK3_CHECK_SCALE,100
EK3_DRAG_BCOEF_X,0
EK3_DRAG_BCOEF_Y,0
EK3_DRAG_M_NSE,0.5
EK3_DRAG_MCOEF,0
EK3_EAS_I_GATE,400
EK3_EAS_M_NSE,1.4
EK3_ENABLE,1
EK3_ERR_THRESH,0.2
EK3_FLOW_DELAY,10
EK3_FLOW_I_GATE,300
EK3_FLOW_M_NSE,0.25
EK3_FLOW_USE,1
EK3_GBIAS_P_NSE,0.001
EK3_GLITCH_RAD,25
EK3_GND_EFF_DZ,4
EK3_GPS_CHECK,31
EK3_GPS_VACC_MAX,0
EK3_GSF_RST_MAX,2
EK3_GSF_RUN_MASK,3
EK3_GSF_USE_MASK,3
EK3_GYRO_P_NSE,0.015
EK3_HGT_DELAY,60
EK3_HGT_I_GATE,500
EK3_HRT_FILT,2
EK3_IMU_MASK,1
EK3_LOG_LEVEL,0
EK3_MAG_CAL,3
EK3_MAG_EF_LIM,50
EK3_MAG_I_GATE,300
EK3_MAG_M_NSE,0.05
EK3_MAG_MASK,0
EK3_MAGB_P_NSE,0.0001
EK3_MAGE_P_NSE,0.001
EK3_MAX_FLOW,2.5
EK3_NOAID_M_NSE,10
EK3_OGN_HGT_MASK,0
EK3_OGNM_TEST_SF,2
EK3_POS_I_GATE,500
EK3_POSNE_M_NSE,0.5
EK3_PRIMARY,0
EK3_RNG_I_GATE,500
EK3_RNG_M_NSE,0.5
EK3_RNG_USE_HGT,-1
EK3_RNG_USE_SPD,2
EK3_SRC_OPTIONS,1
EK3_SRC1_POSXY,3
EK3_SRC1_POSZ,1
EK3_SRC1_VELXY,3
EK3_SRC1_VELZ,3
EK3_SRC1_YAW,8
EK3_SRC2_POSXY,0
EK3_SRC2_POSZ,1
EK3_SRC2_VELXY,0
EK3_SRC2_VELZ,0
EK3_SRC2_YAW,0
EK3_SRC3_POSXY,0
EK3_SRC3_POSZ,1
EK3_SRC3_VELXY,0
EK3_SRC3_VELZ,0
EK3_SRC3_YAW,0
EK3_TAU_OUTPUT,25
EK3_TERR_GRAD,0.1
EK3_VEL_I_GATE,500
EK3_VELD_M_NSE,0.5
EK3_VELNE_M_NSE,0.3
EK3_VIS_VERR_MAX,0.9
EK3_VIS_VERR_MIN,0.1
EK3_WENC_VERR,0.1
EK3_WIND_P_NSE,0.2
EK3_WIND_PSCALE,1
EK3_YAW_I_GATE,300
EK3_YAW_M_NSE,0.5
ESC_CALIBRATION,0
ESC_TLM_MAV_OFS,0
FENCE_ACTION,3
FENCE_ALT_MAX,120
FENCE_ALT_MIN,-10
FENCE_ENABLE,0
FENCE_MARGIN,2
FENCE_RADIUS,150
FENCE_TOTAL,0
FENCE_TYPE,7
FLIGHT_OPTIONS,0
FLTMODE_CH,5
FLTMODE_GCSBLOCK,0
FLTMODE1,0
FLTMODE2,0
FLTMODE3,5
FLTMODE4,5
FLTMODE5,15
FLTMODE6,15
FORMAT_VERSION,120
FRAME_CLASS,1
FRAME_TYPE,1
FRSKY_DNLINK_ID,27
FRSKY_DNLINK1_ID,20
FRSKY_DNLINK2_ID,7
FRSKY_OPTIONS,0
FRSKY_UPLINK_ID,13
FS_CRASH_CHECK,1
FS_DR_ENABLE,2
FS_DR_TIMEOUT,30
FS_EKF_ACTION,1
FS_EKF_FILT,5
FS_EKF_THRESH,0.8
FS_GCS_ENABLE,0
FS_GCS_TIMEOUT,5
FS_OPTIONS,16
FS_THR_ENABLE,1
FS_THR_VALUE,950
FS_VIBE_ENABLE,1
GCS_PID_MASK,0
GND_EFFECT_COMP,1
GPS_AUTO_CONFIG,1
GPS_AUTO_SWITCH,1
GPS_BLEND_MASK,5
GPS_DELAY_MS,0
GPS_DELAY_MS2,0
GPS_DRV_OPTIONS,0
GPS_GNSS_MODE,0
GPS_GNSS_MODE2,0
GPS_HDOP_GOOD,140
GPS_INJECT_TO,127
GPS_MIN_DGPS,100
GPS_MIN_ELEV,-100
GPS_NAVFILTER,8
GPS_POS1_X,0
GPS_POS1_Y,0
GPS_POS1_Z,0
GPS_POS2_X,0
GPS_POS2_Y,0
GPS_POS2_Z,0
GPS_PRIMARY,0
GPS_RATE_MS,200
GPS_RATE_MS2,200
GPS_RAW_DATA,0
GPS_SAVE_CFG,2
GPS_SBAS_MODE,2
GPS_TYPE,1
GPS_TYPE2,0
GUID_OPTIONS,0
GUID_TIMEOUT,3
INITIAL_MODE,0
INS_ACC_BODYFIX,2
INS_ACC_ID,1245450
INS_ACC2_ID,0
INS_ACC2OFFS_X,0
INS_ACC2OFFS_Y,0
INS_ACC2OFFS_Z,0
INS_ACC2SCAL_X,1
INS_ACC2SCAL_Y,1
INS_ACC2SCAL_Z,1
INS_ACCEL_FILTER,20
INS_ACCOFFS_X,-0.0799145
INS_ACCOFFS_Y,-0.5096604
INS_ACCOFFS_Z,1.549907
INS_ACCSCAL_X,0.9911225
INS_ACCSCAL_Y,0.9925686
INS_ACCSCAL_Z,0.975793
INS_ENABLE_MASK,127
INS_FAST_SAMPLE,1
INS_GYR_CAL,1
INS_GYR_ID,2162954
INS_GYR2_ID,0
INS_GYR2OFFS_X,0
INS_GYR2OFFS_Y,0
INS_GYR2OFFS_Z,0
INS_GYRO_FILTER,75
INS_GYRO_RATE,0
INS_GYROFFS_X,-0.006647
INS_GYROFFS_Y,0.0227701
INS_GYROFFS_Z,-0.0106632
INS_HNTC2_ENABLE,0
INS_HNTCH_ATT,40
INS_HNTCH_BW,40
INS_HNTCH_ENABLE,1
INS_HNTCH_FM_RAT,1
INS_HNTCH_FREQ,80
INS_HNTCH_HMNCS,3
INS_HNTCH_MODE,3
INS_HNTCH_OPTS,0
INS_HNTCH_REF,1
INS_LOG_BAT_CNT,1024
INS_LOG_BAT_LGCT,32
INS_LOG_BAT_LGIN,20
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
INS_POS1_X,0
INS_POS1_Y,0
INS_POS1_Z,0
INS_POS2_X,0
INS_POS2_Y,0
INS_POS2_Z,0
INS_RAW_LOG_OPT,0
INS_STILL_THRESH,2.5
INS_TRIM_OPTION,1
INS_USE,1
INS_USE2,1
LAND_ALT_LOW,1000
LAND_REPOSITION,1
LAND_SPEED,50
LAND_SPEED_HIGH,0
LGR_ENABLE,0
LOG_BACKEND_TYPE,1
LOG_BITMASK,141310
LOG_DARM_RATEMAX,0
LOG_DISARMED,0
LOG_FILE_BUFSIZE,16
LOG_FILE_DSRMROT,0
LOG_FILE_MB_FREE,500
LOG_FILE_RATEMAX,0
LOG_FILE_TIMEOUT,5
LOG_MAV_BUFSIZE,8
LOG_MAV_RATEMAX,0
LOG_MAX_FILES,500
LOG_REPLAY,0
LOIT_ACC_MAX,500
LOIT_ANG_MAX,0
LOIT_BRK_ACCEL,250
LOIT_BRK_DELAY,1
LOIT_BRK_JERK,500
LOIT_SPEED,1500
MIS_OPTIONS,0
MIS_RESTART,0
MIS_TOTAL,0
MOT_BAT_CURR_MAX,0
MOT_BAT_CURR_TC,5
MOT_BAT_IDX,0
MOT_BAT_VOLT_MAX,25.2
MOT_BAT_VOLT_MIN,19.8
MOT_BOOST_SCALE,0
MOT_HOVER_LEARN,2
MOT_OPTIONS,0
MOT_PWM_MAX,2000
MOT_PWM_MIN,1000
MOT_PWM_TYPE,6
MOT_SAFE_DISARM,0
MOT_SAFE_TIME,1
MOT_SLEW_DN_TIME,0
MOT_SLEW_UP_TIME,0
MOT_SPIN_ARM,0.1
MOT_SPIN_MAX,0.95
MOT_SPIN_MIN,0.15
MOT_SPOOL_TIM_DN,0
MOT_SPOOL_TIME,0.5
MOT_THST_EXPO,0
MOT_THST_HOVER,0.125
MOT_YAW_HEADROOM,200
MSP_OPTIONS,0
MSP_OSD_NCELLS,0
NTF_BUZZ_ON_LVL,1
NTF_BUZZ_PIN,80
NTF_BUZZ_TYPES,3
NTF_BUZZ_VOLUME,100
NTF_LED_BRIGHT,3
NTF_LED_LEN,1
NTF_LED_OVERRIDE,0
NTF_LED_TYPES,122887
OSD_ARM_SCR,1
OSD_BTN_DELAY,300
OSD_CELL_COUNT,6
OSD_CHAN,0
OSD_DSARM_SCR,2
OSD_FONT,1
OSD_FS_SCR,1
OSD_H_OFFSET,32
OSD_MSG_TIME,15
OSD_OPTIONS,1
OSD_SW_METHOD,0
OSD_TYPE,1
OSD_TYPE2,0
OSD_UNITS,0
OSD_V_OFFSET,16
OSD_W_ACRVOLT,3.5
OSD_W_AVGCELLV,3.5
OSD_W_BATVOLT,21
OSD_W_NSAT,6
OSD_W_RESTVOLT,10
OSD_W_RSSI,80
OSD_W_TERR,-1
OSD1_ACRVOLT_EN,0
OSD1_ACRVOLT_X,24
OSD1_ACRVOLT_Y,4
OSD1_ALTITUDE_EN,1
OSD1_ALTITUDE_X,23
OSD1_ALTITUDE_Y,7
OSD1_ARMING_EN,0
OSD1_ARMING_X,13
OSD1_ARMING_Y,6
OSD1_ASPD1_EN,0
OSD1_ASPD1_X,0
OSD1_ASPD1_Y,0
OSD1_ASPD2_EN,0
OSD1_ASPD2_X,0
OSD1_ASPD2_Y,0
OSD1_ASPEED_EN,0
OSD1_ASPEED_X,2
OSD1_ASPEED_Y,13
OSD1_ATEMP_EN,0
OSD1_ATEMP_X,0
OSD1_ATEMP_Y,0
OSD1_AVGCELLV_EN,1
OSD1_AVGCELLV_X,1
OSD1_AVGCELLV_Y,12
OSD1_BAT_VOLT_EN,1
OSD1_BAT_VOLT_X,1
OSD1_BAT_VOLT_Y,13
OSD1_BAT2_VLT_EN,0
OSD1_BAT2_VLT_X,0
OSD1_BAT2_VLT_Y,0
OSD1_BAT2USED_EN,0
OSD1_BAT2USED_X,0
OSD1_BAT2USED_Y,0
OSD1_BATTBAR_EN,0
OSD1_BATTBAR_X,12
OSD1_BATTBAR_Y,12
OSD1_BATUSED_EN,1
OSD1_BATUSED_X,0
OSD1_BATUSED_Y,15
OSD1_BTEMP_EN,0
OSD1_BTEMP_X,0
OSD1_BTEMP_Y,0
OSD1_CALLSIGN_EN,1
OSD1_CALLSIGN_X,11
OSD1_CALLSIGN_Y,15
OSD1_CELLVOLT_EN,0
OSD1_CELLVOLT_X,1
OSD1_CELLVOLT_Y,11
OSD1_CHAN_MAX,0
OSD1_CHAN_MIN,0
OSD1_CLIMBEFF_EN,0
OSD1_CLIMBEFF_X,0
OSD1_CLIMBEFF_Y,0
OSD1_CLK_EN,1
OSD1_CLK_X,12
OSD1_CLK_Y,12
OSD1_COMPASS_EN,1
OSD1_COMPASS_X,15
OSD1_COMPASS_Y,1
OSD1_CRSSHAIR_EN,0
OSD1_CRSSHAIR_X,0
OSD1_CRSSHAIR_Y,0
OSD1_CURRENT_EN,1
OSD1_CURRENT_X,2
OSD1_CURRENT_Y,14
OSD1_CURRENT2_EN,0
OSD1_CURRENT2_X,0
OSD1_CURRENT2_Y,0
OSD1_DIST_EN,0
OSD1_DIST_X,22
OSD1_DIST_Y,11
OSD1_EFF_EN,0
OSD1_EFF_X,0
OSD1_EFF_Y,15
OSD1_ENABLE,1
OSD1_ESCAMPS_EN,1
OSD1_ESCAMPS_X,21
OSD1_ESCAMPS_Y,14
OSD1_ESCRPM_EN,1
OSD1_ESCRPM_X,24
OSD1_ESCRPM_Y,13
OSD1_ESCTEMP_EN,1
OSD1_ESCTEMP_X,25
OSD1_ESCTEMP_Y,14
OSD1_FENCE_EN,0
OSD1_FENCE_X,14
OSD1_FENCE_Y,9
OSD1_FLTIME_EN,1
OSD1_FLTIME_X,21
OSD1_FLTIME_Y,12
OSD1_FLTMODE_EN,1
OSD1_FLTMODE_X,24
OSD1_FLTMODE_Y,1
OSD1_FONT,0
OSD1_GPSLAT_EN,1
OSD1_GPSLAT_X,8
OSD1_GPSLAT_Y,13
OSD1_GPSLONG_EN,1
OSD1_GPSLONG_X,8
OSD1_GPSLONG_Y,14
OSD1_GSPEED_EN,1
OSD1_GSPEED_X,1
OSD1_GSPEED_Y,8
OSD1_HDOP_EN,0
OSD1_HDOP_X,0
OSD1_HDOP_Y,0
OSD1_HEADING_EN,0
OSD1_HEADING_X,13
OSD1_HEADING_Y,2
OSD1_HOME_EN,1
OSD1_HOME_X,12
OSD1_HOME_Y,2
OSD1_HOMEDIR_EN,0
OSD1_HOMEDIR_X,24
OSD1_HOMEDIR_Y,2
OSD1_HOMEDIST_EN,0
OSD1_HOMEDIST_X,24
OSD1_HOMEDIST_Y,3
OSD1_HORIZON_EN,1
OSD1_HORIZON_X,14
OSD1_HORIZON_Y,8
OSD1_LINK_Q_EN,0
OSD1_LINK_Q_X,1
OSD1_LINK_Q_Y,3
OSD1_MESSAGE_EN,1
OSD1_MESSAGE_X,1
OSD1_MESSAGE_Y,11
OSD1_PITCH_EN,0
OSD1_PITCH_X,0
OSD1_PITCH_Y,0
OSD1_POWER_EN,0
OSD1_POWER_X,23
OSD1_POWER_Y,11
OSD1_RESTVOLT_EN,0
OSD1_RESTVOLT_X,24
OSD1_RESTVOLT_Y,2
OSD1_RNGF_EN,0
OSD1_RNGF_X,0
OSD1_RNGF_Y,0
OSD1_ROLL_EN,0
OSD1_ROLL_X,0
OSD1_ROLL_Y,0
OSD1_RPM_EN,0
OSD1_RPM_X,2
OSD1_RPM_Y,2
OSD1_RSSI_EN,1
OSD1_RSSI_X,2
OSD1_RSSI_Y,2
OSD1_SATS_EN,1
OSD1_SATS_X,1
OSD1_SATS_Y,1
OSD1_SIDEBARS_EN,0
OSD1_SIDEBARS_X,4
OSD1_SIDEBARS_Y,5
OSD1_STATS_EN,0
OSD1_STATS_X,0
OSD1_STATS_Y,0
OSD1_TEMP_EN,1
OSD1_TEMP_X,25
OSD1_TEMP_Y,4
OSD1_TER_HGT_EN,0
OSD1_TER_HGT_X,23
OSD1_TER_HGT_Y,8
OSD1_THROTTLE_EN,1
OSD1_THROTTLE_X,1
OSD1_THROTTLE_Y,9
OSD1_TXT_RES,0
OSD1_VSPEED_EN,1
OSD1_VSPEED_X,24
OSD1_VSPEED_Y,8
OSD1_VTX_PWR_EN,0
OSD1_VTX_PWR_X,0
OSD1_VTX_PWR_Y,0
OSD1_WAYPOINT_EN,0
OSD1_WAYPOINT_X,0
OSD1_WAYPOINT_Y,0
OSD1_WIND_EN,0
OSD1_WIND_X,2
OSD1_WIND_Y,7
OSD1_XTRACK_EN,0
OSD1_XTRACK_X,0
OSD1_XTRACK_Y,0
OSD2_ACRVOLT_EN,0
OSD2_ACRVOLT_X,24
OSD2_ACRVOLT_Y,4
OSD2_ALTITUDE_EN,1
OSD2_ALTITUDE_X,23
OSD2_ALTITUDE_Y,7
OSD2_ARMING_EN,0
OSD2_ARMING_X,13
OSD2_ARMING_Y,6
OSD2_ASPD1_EN,0
OSD2_ASPD1_X,0
OSD2_ASPD1_Y,0
OSD2_ASPD2_EN,0
OSD2_ASPD2_X,0
OSD2_ASPD2_Y,0
OSD2_ASPEED_EN,0
OSD2_ASPEED_X,2
OSD2_ASPEED_Y,13
OSD2_ATEMP_EN,0
OSD2_ATEMP_X,0
OSD2_ATEMP_Y,0
OSD2_AVGCELLV_EN,1
OSD2_AVGCELLV_X,1
OSD2_AVGCELLV_Y,12
OSD2_BAT_VOLT_EN,1
OSD2_BAT_VOLT_X,1
OSD2_BAT_VOLT_Y,13
OSD2_BAT2_VLT_EN,0
OSD2_BAT2_VLT_X,0
OSD2_BAT2_VLT_Y,0
OSD2_BAT2USED_EN,0
OSD2_BAT2USED_X,0
OSD2_BAT2USED_Y,0
OSD2_BATTBAR_EN,0
OSD2_BATTBAR_X,12
OSD2_BATTBAR_Y,12
OSD2_BATUSED_EN,0
OSD2_BATUSED_X,1
OSD2_BATUSED_Y,14
OSD2_BTEMP_EN,0
OSD2_BTEMP_X,0
OSD2_BTEMP_Y,0
OSD2_CALLSIGN_EN,1
OSD2_CALLSIGN_X,11
OSD2_CALLSIGN_Y,15
OSD2_CELLVOLT_EN,1
OSD2_CELLVOLT_X,6
OSD2_CELLVOLT_Y,12
OSD2_CHAN_MAX,2100
OSD2_CHAN_MIN,900
OSD2_CLIMBEFF_EN,0
OSD2_CLIMBEFF_X,0
OSD2_CLIMBEFF_Y,0
OSD2_CLK_EN,1
OSD2_CLK_X,12
OSD2_CLK_Y,12
OSD2_COMPASS_EN,1
OSD2_COMPASS_X,15
OSD2_COMPASS_Y,1
OSD2_CRSSHAIR_EN,0
OSD2_CRSSHAIR_X,0
OSD2_CRSSHAIR_Y,0
OSD2_CURRENT_EN,1
OSD2_CURRENT_X,2
OSD2_CURRENT_Y,14
OSD2_CURRENT2_EN,0
OSD2_CURRENT2_X,0
OSD2_CURRENT2_Y,0
OSD2_DIST_EN,0
OSD2_DIST_X,22
OSD2_DIST_Y,11
OSD2_EFF_EN,0
OSD2_EFF_X,0
OSD2_EFF_Y,15
OSD2_ENABLE,1
OSD2_ESCAMPS_EN,1
OSD2_ESCAMPS_X,21
OSD2_ESCAMPS_Y,14
OSD2_ESCRPM_EN,1
OSD2_ESCRPM_X,24
OSD2_ESCRPM_Y,13
OSD2_ESCTEMP_EN,1
OSD2_ESCTEMP_X,25
OSD2_ESCTEMP_Y,14
OSD2_FENCE_EN,0
OSD2_FENCE_X,14
OSD2_FENCE_Y,9
OSD2_FLTIME_EN,1
OSD2_FLTIME_X,21
OSD2_FLTIME_Y,12
OSD2_FLTMODE_EN,1
OSD2_FLTMODE_X,24
OSD2_FLTMODE_Y,1
OSD2_FONT,0
OSD2_GPSLAT_EN,1
OSD2_GPSLAT_X,8
OSD2_GPSLAT_Y,13
OSD2_GPSLONG_EN,1
OSD2_GPSLONG_X,8
OSD2_GPSLONG_Y,14
OSD2_GSPEED_EN,1
OSD2_GSPEED_X,1
OSD2_GSPEED_Y,8
OSD2_HDOP_EN,0
OSD2_HDOP_X,0
OSD2_HDOP_Y,0
OSD2_HEADING_EN,0
OSD2_HEADING_X,13
OSD2_HEADING_Y,2
OSD2_HOME_EN,1
OSD2_HOME_X,12
OSD2_HOME_Y,2
OSD2_HOMEDIR_EN,0
OSD2_HOMEDIR_X,24
OSD2_HOMEDIR_Y,2
OSD2_HOMEDIST_EN,0
OSD2_HOMEDIST_X,24
OSD2_HOMEDIST_Y,3
OSD2_HORIZON_EN,0
OSD2_HORIZON_X,14
OSD2_HORIZON_Y,8
OSD2_LINK_Q_EN,0
OSD2_LINK_Q_X,1
OSD2_LINK_Q_Y,3
OSD2_MESSAGE_EN,1
OSD2_MESSAGE_X,1
OSD2_MESSAGE_Y,11
OSD2_PITCH_EN,0
OSD2_PITCH_X,0
OSD2_PITCH_Y,0
OSD2_POWER_EN,0
OSD2_POWER_X,23
OSD2_POWER_Y,11
OSD2_RESTVOLT_EN,0
OSD2_RESTVOLT_X,24
OSD2_RESTVOLT_Y,2
OSD2_RNGF_EN,0
OSD2_RNGF_X,0
OSD2_RNGF_Y,0
OSD2_ROLL_EN,0
OSD2_ROLL_X,0
OSD2_ROLL_Y,0
OSD2_RPM_EN,0
OSD2_RPM_X,2
OSD2_RPM_Y,2
OSD2_RSSI_EN,1
OSD2_RSSI_X,2
OSD2_RSSI_Y,2
OSD2_SATS_EN,1
OSD2_SATS_X,1
OSD2_SATS_Y,1
OSD2_SIDEBARS_EN,0
OSD2_SIDEBARS_X,4
OSD2_SIDEBARS_Y,5
OSD2_STATS_EN,1
OSD2_STATS_X,9
OSD2_STATS_Y,3
OSD2_TEMP_EN,1
OSD2_TEMP_X,25
OSD2_TEMP_Y,4
OSD2_TER_HGT_EN,0
OSD2_TER_HGT_X,23
OSD2_TER_HGT_Y,8
OSD2_THROTTLE_EN,1
OSD2_THROTTLE_X,1
OSD2_THROTTLE_Y,9
OSD2_TXT_RES,0
OSD2_VSPEED_EN,1
OSD2_VSPEED_X,24
OSD2_VSPEED_Y,8
OSD2_VTX_PWR_EN,0
OSD2_VTX_PWR_X,0
OSD2_VTX_PWR_Y,0
OSD2_WAYPOINT_EN,0
OSD2_WAYPOINT_X,0
OSD2_WAYPOINT_Y,0
OSD2_WIND_EN,0
OSD2_WIND_X,2
OSD2_WIND_Y,7
OSD2_XTRACK_EN,0
OSD2_XTRACK_X,0
OSD2_XTRACK_Y,0
OSD3_ENABLE,0
OSD3_FONT,0
OSD3_LINK_Q_EN,0
OSD3_LINK_Q_X,1
OSD3_LINK_Q_Y,1
OSD3_TXT_RES,0
OSD4_ENABLE,0
OSD4_FONT,0
OSD4_LINK_Q_EN,0
OSD4_LINK_Q_X,1
OSD4_LINK_Q_Y,1
OSD4_TXT_RES,0
OSD5_ENABLE,0
OSD6_ENABLE,0
PHLD_BRAKE_ANGLE,3000
PHLD_BRAKE_RATE,8
PILOT_ACCEL_Z,250
PILOT_SPEED_DN,0
PILOT_SPEED_UP,300
PILOT_THR_BHV,0
PILOT_THR_FILT,0
PILOT_TKOFF_ALT,0
PILOT_Y_EXPO,0
PILOT_Y_RATE,202.5
PILOT_Y_RATE_TC,0
PLDP_DELAY,0
PLDP_RNG_MIN,0
PLDP_SPEED_DN,0
PLDP_THRESH,0.9
PSC_ACCZ_D,0
PSC_ACCZ_D_FF,0
PSC_ACCZ_FF,0
PSC_ACCZ_FLTD,0
PSC_ACCZ_FLTE,20
PSC_ACCZ_FLTT,0
PSC_ACCZ_I,0.4
PSC_ACCZ_IMAX,800
PSC_ACCZ_P,0.2
PSC_ACCZ_PDMX,0
PSC_ACCZ_SMAX,0
PSC_ANGLE_MAX,0
PSC_JERK_XY,5
PSC_JERK_Z,5
PSC_POSXY_P,1
PSC_POSZ_P,1
PSC_VELXY_D,0.5
PSC_VELXY_FF,0
PSC_VELXY_FLTD,5
PSC_VELXY_FLTE,5
PSC_VELXY_I,1
PSC_VELXY_IMAX,1000
PSC_VELXY_P,2
PSC_VELZ_D,0
PSC_VELZ_FF,0
PSC_VELZ_FLTD,5
PSC_VELZ_FLTE,5
PSC_VELZ_I,0
PSC_VELZ_IMAX,1000
PSC_VELZ_P,5
RALLY_INCL_HOME,1
RALLY_LIMIT_KM,0.3
RALLY_TOTAL,0
RC_FS_TIMEOUT,1
RC_OPTIONS,288
RC_OVERRIDE_TIME,3
RC_PROTOCOLS,1
RC_SPEED,490
RC1_DZ,20
RC1_MAX,1900
RC1_MIN,1100
RC1_OPTION,0
RC1_REVERSED,0
RC1_TRIM,1500
RC10_DZ,0
RC10_MAX,1900
RC10_MIN,1100
RC10_OPTION,0
RC10_REVERSED,0
RC10_TRIM,1500
RC11_DZ,0
RC11_MAX,1900
RC11_MIN,1100
RC11_OPTION,0
RC11_REVERSED,0
RC11_TRIM,1500
RC12_DZ,0
RC12_MAX,1900
RC12_MIN,1100
RC12_OPTION,0
RC12_REVERSED,0
RC12_TRIM,1500
RC13_DZ,0
RC13_MAX,1900
RC13_MIN,1100
RC13_OPTION,0
RC13_REVERSED,0
RC13_TRIM,1500
RC14_DZ,0
RC14_MAX,1900
RC14_MIN,1100
RC14_OPTION,0
RC14_REVERSED,0
RC14_TRIM,1500
RC15_DZ,0
RC15_MAX,1900
RC15_MIN,1100
RC15_OPTION,0
RC15_REVERSED,0
RC15_TRIM,1500
RC16_DZ,0
RC16_MAX,1900
RC16_MIN,1100
RC16_OPTION,0
RC16_REVERSED,0
RC16_TRIM,1500
RC2_DZ,20
RC2_MAX,1900
RC2_MIN,1100
RC2_OPTION,0
RC2_REVERSED,0
RC2_TRIM,1500
RC3_DZ,30
RC3_MAX,1900
RC3_MIN,1100
RC3_OPTION,0
RC3_REVERSED,0
RC3_TRIM,1500
RC4_DZ,20
RC4_MAX,1900
RC4_MIN,1100
RC4_OPTION,0
RC4_REVERSED,0
RC4_TRIM,1500
RC5_DZ,0
RC5_MAX,1900
RC5_MIN,1100
RC5_OPTION,0
RC5_REVERSED,0
RC5_TRIM,1500
RC6_DZ,0
RC6_MAX,1900
RC6_MIN,1100
RC6_OPTION,154
RC6_REVERSED,0
RC6_TRIM,1500
RC7_DZ,0
RC7_MAX,1900
RC7_MIN,1100
RC7_OPTION,0
RC7_REVERSED,0
RC7_TRIM,1500
RC8_DZ,0
RC8_MAX,1900
RC8_MIN,1100
RC8_OPTION,30
RC8_REVERSED,0
RC8_TRIM,1500
RC9_DZ,0
RC9_MAX,1900
RC9_MIN,1100
RC9_OPTION,4
RC9_REVERSED,0
RC9_TRIM,1500
RCMAP_PITCH,2
RCMAP_ROLL,1
RCMAP_THROTTLE,3
RCMAP_YAW,4
RELAY1_FUNCTION,0
RELAY2_FUNCTION,0
RELAY3_FUNCTION,0
RELAY4_FUNCTION,0
RELAY5_FUNCTION,0
RELAY6_FUNCTION,0
RNGFND_FILT,0.5
RNGFND1_TYPE,0
RNGFND2_TYPE,0
RNGFND3_TYPE,0
RNGFND4_TYPE,0
RNGFND5_TYPE,0
RNGFND6_TYPE,0
RNGFND7_TYPE,0
RNGFND8_TYPE,0
RNGFND9_TYPE,0
RNGFNDA_TYPE,0
RPM1_ESC_INDEX,0
RPM1_ESC_MASK,15
RPM1_MAX,100000
RPM1_MIN,10
RPM1_MIN_QUAL,0.5
RPM1_PIN,-1
RPM1_SCALING,1
RPM1_TYPE,5
RPM2_TYPE,0
RSSI_ANA_PIN,15
RSSI_CHAN_HIGH,2000
RSSI_CHAN_LOW,1000
RSSI_CHANNEL,12
RSSI_PIN_HIGH,5
RSSI_PIN_LOW,0
RSSI_TYPE,2
RTL_ALT,5000
RTL_ALT_FINAL,0
RTL_ALT_TYPE,0
RTL_CLIMB_MIN,0
RTL_CONE_SLOPE,3
RTL_LOIT_TIME,5000
RTL_OPTIONS,0
RTL_SPEED,0
SCHED_DEBUG,0
SCHED_LOOP_RATE,400
SCHED_OPTIONS,0
SERIAL_PASS1,0
SERIAL_PASS2,-1
SERIAL_PASSTIMO,15
SERIAL0_BAUD,115
SERIAL0_PROTOCOL,2
SERIAL1_BAUD,57
SERIAL1_OPTIONS,0
SERIAL1_PROTOCOL,23
SERIAL3_BAUD,38
SERIAL3_OPTIONS,0
SERIAL3_PROTOCOL,-1
SERIAL4_BAUD,38
SERIAL4_OPTIONS,0
SERIAL4_PROTOCOL,-1
SERIAL5_BAUD,57
SERIAL5_OPTIONS,0
SERIAL5_PROTOCOL,5
SERIAL6_BAUD,115
SERIAL6_OPTIONS,0
SERIAL6_PROTOCOL,16
SERIAL7_BAUD,57
SERIAL7_OPTIONS,0
SERIAL7_PROTOCOL,-1
SERVO_BLH_3DMASK,0
SERVO_BLH_AUTO,1
SERVO_BLH_DEBUG,1
SERVO_BLH_MASK,15
SERVO_BLH_OTYPE,6
SERVO_BLH_POLES,14
SERVO_BLH_PORT,0
SERVO_BLH_RVMASK,0
SERVO_BLH_TEST,0
SERVO_BLH_TMOUT,0
SERVO_BLH_TRATE,10
SERVO_DSHOT_ESC,1
SERVO_DSHOT_RATE,0
SERVO_GPIO_MASK,0
SERVO_RATE,50
SERVO_RC_FS_MSK,0
SERVO1_FUNCTION,33
SERVO1_MAX,2000
SERVO1_MIN,1000
SERVO1_REVERSED,0
SERVO1_TRIM,1000
SERVO10_FUNCTION,0
SERVO10_MAX,1900
SERVO10_MIN,1100
SERVO10_REVERSED,0
SERVO10_TRIM,1500
SERVO11_FUNCTION,0
SERVO11_MAX,1900
SERVO11_MIN,1100
SERVO11_REVERSED,0
SERVO11_TRIM,1500
SERVO12_FUNCTION,0
SERVO12_MAX,1900
SERVO12_MIN,1100
SERVO12_REVERSED,0
SERVO12_TRIM,1500
SERVO13_FUNCTION,0
SERVO13_MAX,1900
SERVO13_MIN,1100
SERVO13_REVERSED,0
SERVO13_TRIM,1500
SERVO14_FUNCTION,0
SERVO14_MAX,1900
SERVO14_MIN,1100
SERVO14_REVERSED,0
SERVO14_TRIM,1500
SERVO15_FUNCTION,0
SERVO15_MAX,1900
SERVO15_MIN,1100
SERVO15_REVERSED,0
SERVO15_TRIM,1500
SERVO16_FUNCTION,0
SERVO16_MAX,1900
SERVO16_MIN,1100
SERVO16_REVERSED,0
SERVO16_TRIM,1500
SERVO2_FUNCTION,35
SERVO2_MAX,2000
SERVO2_MIN,1000
SERVO2_REVERSED,0
SERVO2_TRIM,1000
SERVO3_FUNCTION,36
SERVO3_MAX,2000
SERVO3_MIN,1000
SERVO3_REVERSED,0
SERVO3_TRIM,1000
SERVO4_FUNCTION,34
SERVO4_MAX,2000
SERVO4_MIN,1000
SERVO4_REVERSED,0
SERVO4_TRIM,1000
SERVO5_FUNCTION,0
SERVO5_MAX,1900
SERVO5_MIN,1100
SERVO5_REVERSED,0
SERVO5_TRIM,1500
SERVO6_FUNCTION,0
SERVO6_MAX,1900
SERVO6_MIN,1100
SERVO6_REVERSED,0
SERVO6_TRIM,1500
SERVO7_FUNCTION,0
SERVO7_MAX,1900
SERVO7_MIN,1100
SERVO7_REVERSED,0
SERVO7_TRIM,1500
SERVO8_FUNCTION,0
SERVO8_MAX,1900
SERVO8_MIN,1100
SERVO8_REVERSED,0
SERVO8_TRIM,1500
SERVO9_FUNCTION,0
SERVO9_MAX,1900
SERVO9_MIN,1100
SERVO9_REVERSED,0
SERVO9_TRIM,1500
SIMPLE,0
SR0_ADSB,0
SR0_EXT_STAT,2
SR0_EXTRA1,4
SR0_EXTRA2,4
SR0_EXTRA3,2
SR0_PARAMS,0
SR0_POSITION,2
SR0_RAW_CTRL,0
SR0_RAW_SENS,2
SR0_RC_CHAN,2
SR1_ADSB,0
SR1_EXT_STAT,0
SR1_EXTRA1,0
SR1_EXTRA2,0
SR1_EXTRA3,0
SR1_PARAMS,0
SR1_POSITION,0
SR1_RAW_CTRL,0
SR1_RAW_SENS,0
SR1_RC_CHAN,0
SR2_ADSB,0
SR2_EXT_STAT,0
SR2_EXTRA1,0
SR2_EXTRA2,0
SR2_EXTRA3,0
SR2_PARAMS,0
SR2_POSITION,0
SR2_RAW_CTRL,0
SR2_RAW_SENS,0
SR2_RC_CHAN,0
SR3_ADSB,0
SR3_EXT_STAT,0
SR3_EXTRA1,0
SR3_EXTRA2,0
SR3_EXTRA3,0
SR3_PARAMS,0
SR3_POSITION,0
SR3_RAW_CTRL,0
SR3_RAW_SENS,0
SR3_RC_CHAN,0
SR4_ADSB,0
SR4_EXT_STAT,0
SR4_EXTRA1,0
SR4_EXTRA2,0
SR4_EXTRA3,0
SR4_PARAMS,0
SR4_POSITION,0
SR4_RAW_CTRL,0
SR4_RAW_SENS,0
SR4_RC_CHAN,0
SRTL_ACCURACY,2
SRTL_OPTIONS,0
SRTL_POINTS,300
STAT_BOOTCNT,224
STAT_FLTTIME,9899
STAT_RESET,181784768
STAT_RUNTIME,37667
SUPER_SIMPLE,0
SURFTRAK_MODE,1
SURFTRAK_TC,1
SYSID_ENFORCE,0
SYSID_MYGCS,255
SYSID_THISMAV,1
TCAL_ENABLED,0
TELEM_DELAY,0
TERRAIN_ENABLE,0
THR_DZ,100
THROW_ALT_MAX,0
THROW_ALT_MIN,0
THROW_MOT_START,0
THROW_NEXTMODE,18
THROW_TYPE,0
TKOFF_RPM_MAX,0
TKOFF_RPM_MIN,0
TKOFF_SLEW_TIME,2
TKOFF_THR_MAX,0.9
TUNE,0
TUNE_MAX,0
TUNE_MIN,0
VTX_ENABLE,0
WP_NAVALT_MIN,0
WP_YAW_BEHAVIOR,2
WPNAV_ACCEL,250
WPNAV_ACCEL_C,0
WPNAV_ACCEL_Z,100
WPNAV_JERK,1
WPNAV_RADIUS,200
WPNAV_RFND_USE,1
WPNAV_SPEED,1000
WPNAV_SPEED_DN,150
WPNAV_SPEED_UP,250
WPNAV_TER_MARGIN,10
