I created a H frame drone but little did I realised the prop direction is different from X.
Is there any difference between H and X in terms of firmware control?
If I used X frame type on a H frame drone would anything happen?
I remember reading that there actually is a difference regarding frame physics. Definitely set FRAME_TYPE
to 3
and order the motors so they’re spinning correctly.
EDIT, here:
These are supported motor layout. You cannot be creativity without modifying the firmware.
For example, DJI X, Quad CW X, and Quad X have different motor control algorithm.
I am not sure what motor you are using, usually we swap two motor wires to have the opposite direction.
Sadly, that would not be possible unless I completely redo the entire drone. My motor are also in cw and ccw. I wish its as simple as switching the wire. I think i go with x.
What ESCs do you use? BLHeli allows to change direction in the ESC configurator.
