I’m planning to use UAVcast-Pro and I already have Pixhawk 6X.
I saw an article that says it needs a companion computer like Raspberry Pi, but I’m not sure about it.
Is there any hardware I should use?
Thank you!
Thank you!
yes you need a companion computer and a rpi4 would be your best bet. I does run on a zero but is very very slow and not really worth the time. just go with a RPI4 and you’ll be just fine. you’ll also need a cellular wifi usb module that will work in your country.
Thank you!
I’ll buy RPI4.
