The stock Volantex power system was replaced with a Turnigy SK3 3542-1250kv motor and Turnigy AE Series ESC. With the 10" prop, full throttle is only 51amps so my Turnigy AE-100A ESC is overkill. It was in stock in the US warehouse along with the motor so I got it. The goal was to reduce my throttle setting from 60%-70% when flying as a normal plane so that I had more power available when adding the extra weight and drag of the QuadPlane wing. My take-off in MANUAL mode and faster flying in FBWA mode was at 50% throttle or less. My CRUISE mode throttle was 30% to 40% depending upon direction around the field with a CRUISE mode current between 5-15amps. I was very happy with the results!
Greg, I understand that you have abandoned the Ranger conversion, and moved the gear over to your FX-79. Did you find the ranger unsuitable for conversion compared to your other conversions? I have all the parts for the ranger project, but have considered transferring this to my own FX-79 after reading your blog. It seems you have found it a better candidate?
It’s a valid question and my answer has changed with my experience and needs. During my testing of the Ranger EX, I had two sets of wings. As I tested various things to get the QuadPlane conversion working, I was having great success flying it as an APM plane and less success flying it as a QuadPlane. The Ranger EX quad wings became cumbersome with the relatively weak wings not meant for the added weight and twisting and the cables needed to help stabilize them. Other folks, like Rollys and Jacques, have had success but they have also modified their wings.
One of my original goals back when I did the smaller Bix3 conversion was to use two sets of wings so that I could go between a plane and a QuadPlane. The mini Talon conversion convinced me there is merit in a dedicated QuadPlane design. Since I enjoyed flying the Ranger EX as a plane and I could take off from a field without tossing it, I decided to move on to other projects.
I searched a while before I landed on the FX-79 two meter wing. The price and dimensions seemed right and I loved the huge bay area. So far, my conversion project has been a great deal of fun. The wing design and strength required no modifications and I will not have to hand-toss it to get airborne.
It may officially be Spring but we still have snow on the ground here in Upstate NY. I have over 20 test flights backed up and the FX-79 is near the top of my list. So, time will soon tell if this conversion is successful.
Thanks for the response. I’m thinking about switching to the FX-79 also do to the issues others have had with the EX wings… I do have a boxed FX-79 and have already purchased all the quad parts you recommended for the EX. How confident are you in this conversion? I already have "most " of the parts, So I might go ahead and jump in instead of waiting for your forward flight findings.
I’m not sure if you experienced any problems with your airspeed sensor. But in my opinion, the pitot tube should be placed where you have no turbulence from the fuselage. If I look at the pictures, it’s very close to the side of the nose body.
Did you consider just letting it sticking out from the tip of the nose?
At the time, I installed it as an add-on so it was an easier mount right through an existing opening. What you say makes sense but it has been my experience that my mount position works fine. Below is my last flight from September '17 when I tested my new power system. It was a calmer day and the AS sensor tracked the GPS ground speed just fine. I hope to have more fun with my Ranger EX on Memorial weekend as a plane.
I’m not sure what caused such a violent attitude change. In addition to checking your CG, as cala2 suggested, test your elevon control on the ground in FBWA mode. Also, make sure that you have SERVO_AUTO_TRIM enabled.
