I have recently moved to Ardupilot from Betaflight/ INav. I recently tried to test an X Frame F450 Quadcopter with Ardupilot. The Quadcopter was continuously spinning in the Yaw Axis, in other axes, it was very stable.
Auto Log Analysis
Log File C:\Users\hp\AppData\Local\Temp\tmp4A25.tmp.log
Size (kb) 3533.841796875
No of lines 43823
Duration 0:02:10
Vehicletype ArduCopter
Firmware Version V4.0.5
Firmware Hash 3f6b43e3
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (300.88%)
Max mag field length (1670.55) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FS_BATT
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.34, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = GOOD - Motor channel averages = [1300, 1308, 1295, 1349]
Average motor output = 1313
Difference between min and max motor averages = 54
Test: NaNs = FAIL - Found NaN in CTUN.TAlt
Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = GOOD -
Test: Pitch/Roll = UNKNOWN - ‘BarAlt’
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
I have also uploaded the Flight Logs here- https://drive.google.com/file/d/1KPFudQ7eQdzuMOlSdfwVVneQxyKIj4ss/view?usp=sharing
I have a few Question related to the same-
Does it seem like a Calibration Error? I have tried to recalibrate the compass a few times and have also tried to change locations.
Is there some sensor gone wrong in the Flight Controller or GPS?
Thank You
