Hi guys, I have a 7 inch quad that tried to fly away during autotune with loiter enabled. I had to use a motor interlock to bring it down. The quad was quite twitchy on when I initially took put it into a hover in stabilised mode. If anyone could shed some light onto what happened it would be greatly appreciated. The logs are here.
Cheers,
Kieran
Be sure to follow these steps if you haven’t already.
Thanks for the response. I conducted a hover test yesterday and the vibration was within the recommended limits. Do you think that this level of vibration would prohibit getting a good tune? I’m using a Kakute F7 with the foam mounted IMU, I wonder if it would also need shielding from the airflow from the props.
I was just helping another guy with this problem. If you click on my topics you’ll see a mount I posted that fixed the issue. You can also order a dampening mount from Bangood or stateside that’ll fix the issue.
