hi
i have problem with my quad.
After crash using Autotune my quad now go up and down when i start to fly in AltHold mode.
There is way for erase the Autotune and return to previous situation ?
- Wrong topic
- If you did not finished autotune then the parameters did not changed.
- If you do believe that params changed then get an older log file and extract the params and load them back.
- Autotune does not impact altitude holding parameters. More likely the problem caused by the crash.
Hi Eosbandi,
thanks for answer.
Ok then is not a problem of Autotune but posible damage of components.
But when i arm now there is not error messages on the log.
Why wrong topic ?
is not this the section ?
I corrected the topic.
You are confused and need to read the instructions:
