Here is a very high level and non-exhaustive list of new features added to QGroundControl in version 3.3. Not to mention the large number of bug fixes in this release.
Settings
Local NMEA GPS device support.
Video Recording save settings.*
Setup
Parameter Editor - Searching updates as you type characters for near immediate response to searches.
Joystick - Android joystick support.
Plan
NEW - Structure Scan Pattern - Create a multi-layered flight pattern that captures images over vertical surfaces (polygonal or circular). Used for 3d model generation or vertical surface inspection.
Fixed Wing Landing Pattern - You can now adjust the distance from the loiter to land point by either distance or glide slope fall rate.
PX4 GeoFence and Rally Point support.
Terrain height display in lower Mission Item altitude display
Fly
Start/Stop video recording.
Better display of vehicle icons when connected to multiple vehicles.
Multi-Vehicle View supports commands which apply to all vehicles.
Displays vehicles reported from ADS-B sensor.
Analyze
Mavlink console - New support for communicating with Mavlink console.
Does Qgroundcontrol have terrain following available now for the survey missions, I have been following some of the requests on github but am still unsure if terrain following is added yet. Thanks for making a planning software that operates on all OS!!
My Android version updated to 3.3 the other day. I’m liking it a lot.
What would we need to do to get Android to support loading firmware? I use a 13" tablet with a full-size USB port and it will actually power a PH2.1 from the USB port.
I think that is going to be way off in the future. Serial Port support in QGC Android is a real nightmare and currently prevents this from being possible.
By the way, do you decode and display each bit from a mavlink message field with display=“bitmask” attribute ?
Are you using the unit attributes to convert from SI to imperial units ?
@DonLakeFlyer, since 3.2.X the main menu buttons are no more displayed, but still able to click on the area they normally should appear. using latest Windows 10 home insider preview.
Does this version support reverses for Ardurover with virtual joystick? I know this topic have been up before, but can’t find if this version support it or not.
I think someone has figure this out already. Can you put in a GitHub Issue and then we can track down from there. You cal also try the alternate startup links which use OpenGL in different wayts.
