I am having issues uploading a mission to my Skyviper 2450. When uploading I get an sequence error (MAV_MISSION_INVALID_SEQUENCE). I read that some people has issues with this but required to leave home location untouched, which I have and it does not fix this error. Any help would be appreciated.
Turn on PlanManagerLog in QGC: https://docs.qgroundcontrol.com/en/SettingsView/console_logging.html. Try again, save the log and link/attach it here.
I am unable to export log on the IOS app, or unable to figure out how to export… Sorry I am new to this. These are the errors I am recieving
You can take screenshots of the log
Afternoon Not to be a thread hacker “be more than glad to start a new thread” but I have been learning on the SV2450gps for a couple weeks and decided to try QGC on iPad and Android, but I too receive the same error along with PARM5 error when trying to upload a mission. At the moment I’m away from the setup and not able to get a log “which i have never done but read up how to”. Any idea what Parameter 5 that it referring to? Thanks in advance!
Ian
That’s not the right part of the log. I’m going to need someone to reproduce this using a QGC daily build on an OS which can save a log file with PlanManagerLog turned on as described above.
In looking at the ArduPilot firmware code it I could possibly see how this could happen if packets are lost on the WiFi connection to the vehicle. But I’m just guessing without a log.
Don, thanks for looking at this.
Here’s a log from qgc daily build on win 10, with Plan ManagerLog turned on. Message happened multiple times, also unable to upload simple mission. Hope info is the right one? btw, mavlink set to mavlink 1.
[D] at ..\src\QGCApplication.cc:263 - "Settings location "C:/Users/olivier/AppData/Roaming/QGroundControl.org/QGroundControl.ini" Is writable?: true"
[D] at ..\src\QGCLoggingCategory.cc:99 - "Filter rules "qt.network.ssl.warning=false\n*Log.debug=false\nPlanManagerLog.debug=true\n""
[D] at ..\src\PositionManager\PositionManager.cpp:35 - "QGeoPositionInfoSourceWinRT(0x11b98890)"
[D] at ..\src\Vehicle\MAVLinkLogManager.cc:359 - "MAVLink logs directory: "C:/Users/olivier/Documents/QGroundControl/Logs""
[D] at ..\src\QtLocationPlugin\QGCMapEngine.cpp:216 - "Map Cache in: "C:/Users/olivier/AppData/Local/cache/QGCMapCache300" / "qgcMapCache.db""
[E] at ..\src\PositionManager\PositionManager.cpp:94 - "QGCPositionManager error 1"
[D] at ..\src\comm\MAVLinkProtocol.cc:430 - "Temp log "C:/Users/olivier/AppData/Local/Temp/FlightData294301.mavlink""
[E] at :0 - "libpng warning: iCCP: known incorrect sRGB profile"
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Dialogs/DefaultFileDialog.qml:210 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Dialogs/DefaultFileDialog.qml:210:25: QML ListView: Binding loop detected for property "model""
[E] at qrc:///qml/QGroundControl/Controls/QGCFlickableVerticalIndicator.qml:6 - "qrc:///qml/QGroundControl/Controls/QGCFlickableVerticalIndicator.qml:6: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/QGCFlickableHorizontalIndicator.qml:6 - "qrc:///qml/QGroundControl/Controls/QGCFlickableHorizontalIndicator.qml:6: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/MissionItemStatus.qml:35 - "qrc:///qml/QGroundControl/Controls/MissionItemStatus.qml:35: TypeError: Cannot read property 'width' of undefined"
[E] at qrc:///qml/QGroundControl/Controls/MissionItemStatus.qml:67 - "qrc:///qml/QGroundControl/Controls/MissionItemStatus.qml:67: TypeError: Cannot read property 'width' of undefined"
[D] at ..\src\MissionManager\PlanManager.cc:132 - ""loadFromVehicle T:Mission read sequence""
[D] at ..\src\MissionManager\PlanManager.cc:149 - ""_requestList T:Mission _planType:_retryCount" 0 0"
[D] at ..\src\MissionManager\PlanManager.cc:309 - ""_handleMissionCount T:Mission count:" 5"
[D] at ..\src\MissionManager\PlanManager.cc:331 - ""_requestNextMissionItem T:Mission sequenceNumber:retry" 0 0"
[E] at :0 - "QString::arg: Argument missing: Out of sequence ack expected:received MISSION_ITEM:MISSION_REQUEST MISSION_ITEM, T:Mission"
[D] at ..\src\MissionManager\PlanManager.cc:266 - ""Out of sequence ack expected:received MISSION_ITEM:MISSION_REQUEST MISSION_ITEM""
[D] at ..\src\MissionManager\PlanManager.cc:425 - ""_handleMissionItem T:Mission seq:command:current:ardupilotHomePositionUpdate" 0 16 false false"
[D] at ..\src\MissionManager\PlanManager.cc:331 - ""_requestNextMissionItem T:Mission sequenceNumber:retry" 1 0"
[D] at ..\src\MissionManager\PlanManager.cc:457 - ""_handleMissionItem T:Mission mission item received item index which was not requested, disregrarding:" 0"
[D] at ..\src\MissionManager\PlanManager.cc:586 - ""_handleMissionAck T:Mission type:" "Received mission item out of sequence (MAV_MISSION_INVALID_SEQUENCE)""
[D] at ..\src\MissionManager\PlanManager.cc:670 - ""Sending T:Mission error" 5 "Vehicle returned error: Received mission item out of sequence (MAV_MISSION_INVALID_SEQUENCE).""
[D] at ..\src\MissionManager\PlanManager.cc:809 - ""inProgressChanged T:Mission""
[E] at qrc:/qml/MissionSettingsEditor.qml:88 - "qrc:/qml/MissionSettingsEditor.qml:88: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:89 - "qrc:/qml/MissionSettingsEditor.qml:89: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/CameraSection.qml:13 - "qrc:///qml/QGroundControl/Controls/CameraSection.qml:13: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/CameraSection.qml:14 - "qrc:///qml/QGroundControl/Controls/CameraSection.qml:14: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:129 - "qrc:/qml/MissionSettingsEditor.qml:129: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:130 - "qrc:/qml/MissionSettingsEditor.qml:130: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/SectionHeader.qml:11 - "qrc:///qml/QGroundControl/Controls/SectionHeader.qml:11: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/SectionHeader.qml:12 - "qrc:///qml/QGroundControl/Controls/SectionHeader.qml:12: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:145 - "qrc:/qml/MissionSettingsEditor.qml:145: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:146 - "qrc:/qml/MissionSettingsEditor.qml:146: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:166 - "qrc:/qml/MissionSettingsEditor.qml:166: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:167 - "qrc:/qml/MissionSettingsEditor.qml:167: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:230 - "qrc:/qml/MissionSettingsEditor.qml:230: TypeError: Cannot read property of null"
[E] at qrc:/qml/MissionSettingsEditor.qml:231 - "qrc:/qml/MissionSettingsEditor.qml:231: TypeError: Cannot read property of null"
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/Control.qml:88 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/Control.qml:88:5: QML Loader: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/TextField.qml:638 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/TextField.qml:638:5: QML TextInputWithHandles: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/TextInputWithHandles.qml:102 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/TextInputWithHandles.qml:102:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/TextInputWithHandles.qml:124 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/TextInputWithHandles.qml:124:5: QML EditMenu: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/EditMenu_base.qml:44 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/EditMenu_base.qml:44:1: QML EditMenu_base: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/AbstractCheckable.qml:120 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/AbstractCheckable.qml:120:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling."
[E] at qrc:///qml/QGroundControl/Controls/CameraSection.qml:32 - "qrc:///qml/QGroundControl/Controls/CameraSection.qml:32: TypeError: Cannot read property of null"
[E] at qrc:///qml/QGroundControl/Controls/CameraSection.qml:33 - "qrc:///qml/QGroundControl/Controls/CameraSection.qml:33: TypeError: Cannot read property of null"
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtGraphicalEffects/ColorOverlay.qml:128 - "file:///C:/Program Files (x86)/qgroundcontrol/QtGraphicalEffects/ColorOverlay.qml:128:5: QML ShaderEffectSource: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtGraphicalEffects/ColorOverlay.qml:138 - "file:///C:/Program Files (x86)/qgroundcontrol/QtGraphicalEffects/ColorOverlay.qml:138:5: QML ShaderEffect: Cannot anchor to an item that isn't a parent or sibling."
[E] at file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/BasicButton.qml:189 - "file:///C:/Program Files (x86)/qgroundcontrol/QtQuick/Controls/Private/BasicButton.qml:189:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling."
[D] at ..\src\MissionManager\PlanManager.cc:54 - ""writeMissionItems T:Mission count:" 5"
[D] at ..\src\MissionManager\PlanManager.cc:108 - ""_writeMissionCount T:Mission count:_retryCount" 5 0"
[D] at ..\src\MissionManager\PlanManager.cc:496 - ""_handleMissionRequest T:Mission sequenceNumber" 0"
[D] at ..\src\MissionManager\PlanManager.cc:514 - ""_handleMissionRequest T:Mission sequenceNumber:command" 0 16"
[E] at :0 - "QString::arg: Argument missing: Out of sequence ack expected:received MISSION_REQUEST:MISSION_ITEM MISSION_REQUEST, T:Mission"
[D] at ..\src\MissionManager\PlanManager.cc:266 - ""Out of sequence ack expected:received MISSION_REQUEST:MISSION_ITEM MISSION_REQUEST""
[D] at ..\src\MissionManager\PlanManager.cc:425 - ""_handleMissionItem T:Mission seq:command:current:ardupilotHomePositionUpdate" 0 16 false true"
[D] at ..\src\MissionManager\PlanManager.cc:496 - ""_handleMissionRequest T:Mission sequenceNumber" 1"
[D] at ..\src\MissionManager\PlanManager.cc:514 - ""_handleMissionRequest T:Mission sequenceNumber:command" 1 22"
[D] at ..\src\MissionManager\PlanManager.cc:586 - ""_handleMissionAck T:Mission type:" "Received mission item out of sequence (MAV_MISSION_INVALID_SEQUENCE). Sequence: 1""
[D] at ..\src\MissionManager\PlanManager.cc:670 - ""Sending T:Mission error" 5 "Vehicle returned error: Received mission item out of sequence (MAV_MISSION_INVALID_SEQUENCE). Sequence: 1.""
[!] at :0 - "QWindowsNativeFileDialogBase::shellItem: SHCreateItemFromParsingName(file:///c/Users/olivier/Documents/QGroundControl/Logs)) failed (An attempt was made to reference a token that does not exist.)"
[!] at :0 - "QWindowsNativeFileDialogBase::shellItem: SHCreateItemFromParsingName(file:///c/Users/olivier/Documents/QGroundControl/Logs)) failed (The operation completed successfully.)"
Here is what is happening:
- QGC sends REQUEST_LIST to start mission download protocol
- Vehicle responds with MISSION_COUNT of 5
- QGC sends vehicle request for mission item 0
- The vehicle suddenly sends a MISSION_REQUEST instead of returning a MISSION_ITEM which is incorrect mission protocol behavior (this seems to get send multiuple times)
- The vehicle also sends the correct MISSION_ITEM 0
- QGC asks vehicle for mission item 1
- Vehicle sends MISSION_ITEM 0 again
This is all pretty out of whack from a vehicle side mission protocol standpoint. Not really sure what the vehicle firmware is trying to do. But it’s not correct.
It’s almost like thie vehicle side is trying to request a mission upload as well even though the ground station never asked for a mission upload.
Not that I know of. I don’t have a SkyViper so I have no idea what it is trying to do.
Mission Uploads work great on Tower and from MissionPlanner. No issues. You might try Tower and see if it works for you, assuming you have an Android.
I am having same issue here . Some times it will instead say vech did not request all mission targets or some thing along those lines . Tower crashes my tablet every time . I am totally clueless about this stuff but , after reading a wack of msg board posts I remember reading some thing about lowering baud rate … packet loss something or other . But I have no idea where to change that setting . He’ll I can’t even figure out how to read a log file now that I know where they are on tablet . .
The “good” log file isn’t on the tablet. That’s just the one the app recorded. You should pull the micro-SD card (assuming you have one) out of the SV. If you don’t have one, put one in there. It’s used for storing higher quality (relatively) video/images, GPS quick fix data, and dataflash logs.
Yes I have SD card in SV , the one that came with it . I know about data flash logs and can read them in raw form in note pad on tablet .; but If I have Tower installed on the tablet if I try and open a SV data flash log . Tower will automatically open and then crash with a critical error msg popping up.
What I was talking about in my above post is the Tlogs that Qground creates and stores in a folder in tablets memory if I have Qground connected when flying . These logs I can not figure out how to read them, it seems android version of Q has no way to display log files that I can figure out .
Transfer the DATAFLASH logs from th SD card to your PC and use Mission Planner or APM planner 2.0
the tlog is useful for plotting the movements of your drone, but (correct me if i’m wrong) don’t contain all of the logs. It’s just telemetry. I don’t really know the difference honestly. either way, open up the dataflash logs in mission planner
Mobile builds of QGC do not have log replay support. Only desktop builds have that feature.
ChrisOlson shared this advice
I’m still unable to achieve more than Arm and Takeoff while in QGC. After takeoff, I can switch to Auto Mode but the vehicle Loiters only. I have not been able to Load the mission from QGC.
The parameters changed in my 2450 are attached.
Any insights will be appreciated!
Andrew I am having the exact same issue as you . I can some times get it to upload 3 or 4 way points, If I sync multiple times . I can’t get Tower to work either , app crashes on tablet. I don’t have a pc, that I can use to load mission planer to see if that works .
