In the latest version of firmware (arducopter trad heli), with the latest QGC there is no longer an option to set channel 8 to throttle output so I cannot tie throttle output to a knob. This is how I normally fly, I arm, and raise the throttle (with collective pitch at zero) using a knob I programmed into my radio as channel 8. This allows me to have a constant speed at any pitch and is the only way I fly 3d in acro mode. This allows me to adjust the throttle speed at will but its no longer in the menu for “heli”. I had to roll back to QGC 3.5.6 and it returned, but I had to re-flash the older firmware (arducopter-heli-stable-3.6.12) manually as ver 4 had tons of missing parameters. I do not like manually flashing firmware, I prefer to have QGC find the right fmuv2 version firmware on its own and flash it as its safer than manual updates.
Is there any reason for this change and I missed the note somewhere? I cannot use arducopter without this ability and I tried to map it through the full param list but it didnt work. I left it on the older QGC and older firmware but ideally I would like to use the latest version.
Below is the version I am forced to use with the latest QGC and the missing option in ver4:
Thanks in advance and let me know if this is already known and being worked on or if I should report it as a bug somewhere (but where)? I am fine now because both my T-Rex 600 Pro DFC and T-Rex 700 DFC are both using the older firmware (which has the option enabled so all works fine) but I am on the older firmware (3.6.12 and QGC 3.5.6) so I am not on the latest builds of either but would like to be ideally.
NOTE, I now realize that my second picture shows FMUv3 (thats my 700 and was used to show the older firmware RSC channel 8 knob option), my T-Rex 600 Pro uses FMUv2 so thats all accurate.
