I am having trouble finding a short piece by Tridge where he explains how to set up the lua switching etc. I did find it some time ago, but I have lost the link.
Otherwise, I just need some help to get the qautotune for copter working.
I followed all the info on the lua pages and have the qautotune lua in the scripts folder. Have set rc5 option to 300 and have sw C to invoke the start of the tune. But looking at messages, I see the qautotune was called buit failed Mode change to AUTOTUNE failed: init failed. Can this be the lua is not configured properly.
I found the latest file on the git and saved it into notepad++ then saved the file as quicktune.lua and transferred it to the scripts folder. Have I done some thing wrong using notepad++ that causes the lua to fail. Help will be appreciated.
I have just done this. qautotune mode and VTOL quicktune are different. If you want to use VTOL quicktune then you should enable it from qloiter mode not qautotune. If you want to use qautotune then you do not have to do any of the LUA setup.
Hi, thx for your reply. Looking at my post, it may look like I was asking about Q-autotune for a 4+1 plane etc. But I was meaning the new quick autotune for Copter. Tridge made a video some months ago about this new way to tune a plane and I thought I read it was then adapted to run on copter as well. So that must be where I am getting it wrong.
This is the video I watched ref “This is a first attempt at using ArduPilot 4.3.0-DEV with the VTOL Quick Tune Lua script which was originally designed for QuadPlanes but also works for multicopters”
I read this txt "Install the lua script in the APM/SCRIPTS directory on the flight controllers microSD card, then set SCR_ENABLE to 1. Reboot, and refresh parameters. Then set QUIK_ENABLE to 1 ". But I can’t find QUIK_ENABLE
What flight controller? It sounds like scripting isn’t working. Note that if autotune works it will generally give you a better tune.
I am using a pixhawk 2 meg Chinese clone.Here is my lua script
fast tuning of VTOL gains for multirotors and quadplanes
This should be used in QLOITER mode for quadplanes and LOITER mode
for copters, although it will work in other VTOL modes
– luacheck: only 0
- TODO:
- disable weathervaning while tuning?
- possibly lower P XY gains during tuning?
- bail out on a large angle error?
local MAV_SEVERITY_INFO = 6
local MAV_SEVERITY_NOTICE = 5
local MAV_SEVERITY_EMERGENCY = 0
local PARAM_TABLE_KEY = 8
local PARAM_TABLE_PREFIX = “QUIK_”
local is_quadplane = false
local atc_prefix = “ATC”
– bind a parameter to a variable
function bind_param(name)
local p = Parameter()
assert(p:init(name), string.format(‘could not find %s parameter’, name))
return p
end
– add a parameter and bind it to a variable
function bind_add_param(name, idx, default_value)
assert(param:add_param(PARAM_TABLE_KEY, idx, name, default_value), string.format(‘could not add param %s’, name))
return bind_param(PARAM_TABLE_PREFIX … name)
end
– setup quicktune specific parameters
assert(param:add_table(PARAM_TABLE_KEY, PARAM_TABLE_PREFIX, 12), ‘could not add param table’)
// @Param: QUIK_ENABLE
// @DisplayName: Quicktune enable
// @Description: Enable quicktune system
// @Values: 0:Disabled,1:Enabled
// @User: Standard
local QUIK_ENABLE = bind_add_param(‘ENABLE’, 1, 0)
// @Param: QUIK_AXES
// @DisplayName: Quicktune axes
// @Description: axes to tune
// @Bitmask: 0:Roll,1:Pitch,2:Yaw
// @User: Standard
local QUIK_AXES = bind_add_param(‘AXES’, 2, 7)
// @Param: QUIK_DOUBLE_TIME
// @DisplayName: Quicktune doubling time
// @Description: Time to double a tuning parameter. Raise this for a slower tune.
// @Range: 5 20
// @Units: s
// @User: Standard
local QUIK_DOUBLE_TIME = bind_add_param(‘DOUBLE_TIME’, 3, 10)
// @Param: QUIK_GAIN_MARGIN
// @DisplayName: Quicktune gain margin
// @Description: Reduction in gain after oscillation detected. Raise this number to get a more conservative tune
// @Range: 20 80
// @Units: %
// @User: Standard
local QUIK_GAIN_MARGIN = bind_add_param(‘GAIN_MARGIN’, 4, 60)
// @Param: QUIK_OSC_SMAX
// @DisplayName: Quicktune oscillation rate threshold
// @Description: Threshold for oscillation detection. A lower value will lead to a more conservative tune.
// @Range: 1 10
// @User: Standard
local QUIK_OSC_SMAX = bind_add_param(‘OSC_SMAX’, 5, 5)
// @Param: QUIK_YAW_P_MAX
// @DisplayName: Quicktune Yaw P max
// @Description: Maximum value for yaw P gain
// @Range: 0.1 3
// @User: Standard
local QUIK_YAW_P_MAX = bind_add_param(‘YAW_P_MAX’, 6, 0.5)
// @Param: QUIK_YAW_D_MAX
// @DisplayName: Quicktune Yaw D max
// @Description: Maximum value for yaw D gain
// @Range: 0.001 1
// @User: Standard
local QUIK_YAW_D_MAX = bind_add_param(‘YAW_D_MAX’, 7, 0.01)
// @Param: QUIK_RP_PI_RATIO
// @DisplayName: Quicktune roll/pitch PI ratio
// @Description: Ratio between P and I gains for roll and pitch. Raise this to get a lower I gain
// @Range: 0.5 1.0
// @User: Standard
local QUIK_RP_PI_RATIO = bind_add_param(‘RP_PI_RATIO’, 8, 1.0)
// @Param: QUIK_Y_PI_RATIO
// @DisplayName: Quicktune Yaw PI ratio
// @Description: Ratio between P and I gains for yaw. Raise this to get a lower I gain
// @Range: 0.5 20
// @User: Standard
local QUIK_Y_PI_RATIO = bind_add_param(‘Y_PI_RATIO’, 9, 10)
// @Param: QUIK_AUTO_FILTER
// @DisplayName: Quicktune auto filter enable
// @Description: When enabled the PID filter settings are automatically set based on INS_GYRO_FILTER
// @User: Standard
local QUIK_AUTO_FILTER = bind_add_param(‘AUTO_FILTER’, 10, 1)
// @Param: QUIK_AUTO_SAVE
// @DisplayName: Quicktune auto save
// @Description: Number of seconds after completion of tune to auto-save. This is useful when using a 2 position switch for quicktune
// @Units: s
// @User: Standard
local QUIK_AUTO_SAVE = bind_add_param(‘AUTO_SAVE’, 11, 0)
// @Param: QUIK_RC_FUNC
// @DisplayName: Quicktune RC function
// @Description: RCn_OPTION number to use to control tuning stop/start/save
// @User: Standard
local QUIK_RC_FUNC = bind_add_param(‘RC_FUNC’, 12, 300)
local INS_GYRO_FILTER = bind_param(“INS_GYRO_FILTER”)
local RCMAP_ROLL = bind_param(“RCMAP_ROLL”)
local RCMAP_PITCH = bind_param(“RCMAP_PITCH”)
local RCMAP_YAW = bind_param(“RCMAP_YAW”)
local RCIN_ROLL = rc:get_channel(RCMAP_ROLL:get())
local RCIN_PITCH = rc:get_channel(RCMAP_PITCH:get())
local RCIN_YAW = rc:get_channel(RCMAP_YAW:get())
local UPDATE_RATE_HZ = 40
local STAGE_DELAY = 4.0
local PILOT_INPUT_DELAY = 4.0
local YAW_FLTE_MAX = 2.0
local FLTD_MUL = 0.5
local FLTT_MUL = 0.5
– SMAX to set if none set at start
local DEFAULT_SMAX = 50.0
– work out vehicle type
if param:get(“Q_A_RAT_RLL_SMAX”) then
is_quadplane = true
atc_prefix = “Q_A”
gcs:send_text(MAV_SEVERITY_EMERGENCY, “Quicktune for quadplane loaded”)
elseif param:get(“ATC_RAT_RLL_SMAX”) then
gcs:send_text(MAV_SEVERITY_EMERGENCY, “Quicktune for multicopter loaded”)
else
gcs:send_text(MAV_SEVERITY_EMERGENCY, “Quicktune unknown vehicle”)
return
end
– get time in seconds since boot
function get_time()
return millis():tofloat() * 0.001
end
local axis_names = { “RLL”, “PIT”, “YAW” }
local param_suffixes = { “FF”, “P”, “I”, “D”, “SMAX”, “FLTT”, “FLTD”, “FLTE” }
local stages = { “D”, “P” }
local stage = stages[1]
local last_stage_change = get_time()
local last_gain_report = get_time()
local last_pilot_input = get_time()
local last_notice = get_time()
local tune_done_time = nil
local slew_parm = nil
local slew_target = 0
local slew_delta = 0
local axes_done = {}
local filters_done = {}
– create params dictionary indexed by name, such as “RLL_P”
local params = {}
local param_saved = {}
local param_changed = {}
local need_restore = false
for i, axis in ipairs(axis_names) do
for j, suffix in ipairs(param_suffixes) do
local pname = axis … “" … suffix
params[pname] = bind_param(atc_prefix … "” … “RAT_” … pname)
param_changed[pname] = false
end
end
– reset to start
function reset_axes_done()
axes_done[axis] = false
filters_done[axis] = false
end
stage = stages[1]
end
– get all current param values into param_saved dictionary
function get_all_params()
for pname in pairs(params) do
param_saved[pname] = params[pname]:get()
end
end
– restore all param values from param_saved dictionary
function restore_all_params()
local changed = param_changed[pname] and 1 or 0
if param_changed[pname] then
params[pname]:set(param_saved[pname])
end
end
end
– save all param values to storage
function save_all_params()
params[pname]:set_and_save(params[pname]:get())
end
end
end
– setup a default SMAX if zero
function setup_SMAX()
local smax = axis … “_SMAX”
if params[smax]:get() <= 0 then
adjust_gain(smax, DEFAULT_SMAX)
end
end
end
– setup filter frequencies
function setup_filters(axis)
if QUIK_AUTO_FILTER:get() <= 0 then
return
end
local fltd = axis … “_FLTD”
local fltt = axis … “_FLTT”
local flte = axis … “_FLTE”
adjust_gain(fltt, INS_GYRO_FILTER:get() * FLTT_MUL)
adjust_gain(fltd, INS_GYRO_FILTER:get() * FLTD_MUL)
if axis == “YAW” then
local FLTE = params[flte]
if FLTE:get() <= 0.0 or FLTE:get() > YAW_FLTE_MAX then
adjust_gain(flte, YAW_FLTE_MAX)
end
end
filters_done[axis] = true
end
– check for pilot input to pause tune
function have_pilot_input()
if (math.abs(RCIN_ROLL:norm_input_dz()) > 0 or
math.abs(RCIN_PITCH:norm_input_dz()) > 0 or
math.abs(RCIN_YAW:norm_input_dz()) > 0) then
return true
end
return false
end
reset_axes_done()
get_all_params()
function axis_enabled(axis)
local axes = QUIK_AXES:get()
for i = 1, #axis_names do
local mask = (1 << (i-1))
local axis_name = axis_names[i]
if axis == axis_name and (mask & axes) ~= 0 then
return true
end
end
return false
end
– get the axis name we are working on, or nil for all done
function get_current_axis()
if (mask & axes) ~= 0 and axes_done[axis_name] == false then
return axis_names[i]
end
end
return nil
end
– get slew rate for an axis
function get_slew_rate(axis)
local roll_srate, pitch_srate, yaw_srate = AC_AttitudeControl:get_rpy_srate()
if axis == “RLL” then
return roll_srate
end
if axis == “PIT” then
return pitch_srate
end
return yaw_srate
end
return 0.0
end
– move to next stage of tune
function advance_stage(axis)
if stage == “D” then
stage = “P”
else
axes_done[axis] = true
gcs:send_text(5, string.format(“Tuning: %s done”, axis))
stage = “D”
end
end
– get param name, such as RLL_P, used as index into param dictionaries
function get_pname(axis, stage)
return axis … “_” … stage
end
– get axis name from parameter name
function param_axis(pname)
return string.sub(pname, 1, 3)
end
– get parameter suffix from parameter name
function param_suffix(pname)
return string.sub(pname, 4)
end
– change a gain
function adjust_gain(pname, value)
local P = params[pname]
need_restore = true
param_changed[pname] = true
P:set(value)
if string.sub(pname, -2) == “_P” then
– also change I gain
local iname = string.gsub(pname, “_P”, “_I”)
local ffname = string.gsub(pname, “_P”, “_FF”)
local I = params[iname]
local FF = params[ffname]
if FF:get() > 0 then
– if we have any FF on an axis then we don’t couple I to P,
– usually we want I = FF for a one sectond time constant for trim
return
end
param_changed[iname] = true
-- work out ratio of P to I that we want
local PI_ratio = QUIK_RP_PI_RATIO:get()
if param_axis(pname) == "YAW" then
PI_ratio = QUIK_Y_PI_RATIO:get()
end
if PI_ratio >= 1 then
I:set(value/PI_ratio)
end
end
end
– return gain multipler for one loop
function get_gain_mul()
return math.exp(math.log(2.0)/(UPDATE_RATE_HZ*QUIK_DOUBLE_TIME:get()))
end
function setup_slew_gain(pname, gain)
slew_parm = pname
slew_target = gain
slew_steps = UPDATE_RATE_HZ/2
slew_delta = (gain - params[pname]:get()) / slew_steps
end
function update_slew_gain()
if slew_parm ~= nil then
local P = params[slew_parm]
local axis = param_axis(slew_parm)
local ax_stage = string.sub(slew_parm, -1)
adjust_gain(slew_parm, P:get()+slew_delta)
slew_steps = slew_steps - 1
logger.write(‘QUIK’,‘SRate,Gain,Param’, ‘ffn’, get_slew_rate(axis), P:get(), axis … ax_stage)
if slew_steps == 0 then
gcs:send_text(MAV_SEVERITY_INFO, string.format(“%s %.4f”, slew_parm, P:get()))
slew_parm = nil
if get_current_axis() == nil then
gcs:send_text(MAV_SEVERITY_NOTICE, string.format(“Tuning: DONE”))
tune_done_time = get_time()
end
end
end
end
– return gain limits on a parameter, or 0 for no limit
function gain_limit(pname)
if param_axis(pname) == “YAW” then
local suffix = param_suffix(pname)
if suffix == “_P” then
return QUIK_YAW_P_MAX:get()
end
if suffix == “_D” then
return QUIK_YAW_D_MAX:get()
end
end
return 0.0
end
function reached_limit(pname, gain)
local limit = gain_limit(pname)
if limit > 0.0 and gain >= limit then
return true
end
return false
end
– main update function
local last_warning = get_time()
function update()
if have_pilot_input() then
end
local sw_pos = rc:get_aux_cached(QUIK_RC_FUNC:get())
if not sw_pos then
return
end
if sw_pos == 1 and (not arming:is_armed() or not vehicle:get_likely_flying()) and get_time() > last_warning + 5 then
gcs:send_text(MAV_SEVERITY_EMERGENCY, string.format(“Tuning: Must be flying to tune”))
return
end
if sw_pos == 0 or not arming:is_armed() or not vehicle:get_likely_flying() then
– abort, revert parameters
if need_restore then
gcs:send_text(MAV_SEVERITY_EMERGENCY, string.format(“Tuning: reverted”))
end
reset_axes_done()
return
end
if sw_pos == 2 then
– save all params
save_all_params()
gcs:send_text(MAV_SEVERITY_NOTICE, string.format(“Tuning: saved”))
end
end
if sw_pos ~= 1 then
return
end
if get_time() - last_stage_change < STAGE_DELAY then
update_slew_gain()
return
end
axis = get_current_axis()
if axis == nil then
– nothing left to do, check autosave time
if tune_done_time ~= nil and QUIK_AUTO_SAVE:get() > 0 then
if get_time() - tune_done_time > QUIK_AUTO_SAVE:get() then
save_all_params()
end
end
return
end
if not need_restore then
– we are just starting tuning, get current values
gcs:send_text(MAV_SEVERITY_NOTICE, string.format(“Tuning: starting tune”))
get_all_params()
setup_SMAX()
end
if get_time() - last_pilot_input < PILOT_INPUT_DELAY then
return
end
if not filters_done[axis] then
gcs:send_text(MAV_SEVERITY_INFO, string.format(“Starting %s tune”, axis))
setup_filters(axis)
end
local srate = get_slew_rate(axis)
local pname = get_pname(axis, stage)
local oscillating = srate > QUIK_OSC_SMAX:get()
local limited = reached_limit(pname, P:get())
if limited or oscillating then
local reduction = (100.0-QUIK_GAIN_MARGIN:get())*0.01
if not oscillating then
reduction = 1.0
end
local new_gain = P:get() * reduction
if limit > 0.0 and new_gain > limit then
new_gain = limit
end
local old_gain = param_saved[pname]
if new_gain < old_gain and string.sub(pname,-2) == ‘_D’ and param_axis(pname) ~= ‘YAW’ then
– we are lowering a D gain from the original gain. Also lower the P gain by the same amount
– so that we don’t trigger P oscillation. We don’t drop P by more than a factor of 2
local ratio = math.max(new_gain / old_gain, 0.5)
local P_name = string.gsub(pname, “_D”, “_P”)
local old_P = params[P_name]:get()
local new_P = old_P * ratio
gcs:send_text(MAV_SEVERITY_INFO, string.format(“adjusting %s %.3f → %.3f”, P_name, old_P, new_P))
adjust_gain(P_name, new_P)
end
setup_slew_gain(pname, new_gain)
logger.write(‘QUIK’,‘SRate,Gain,Param’, ‘ffn’, srate, P:get(), axis … stage)
gcs:send_text(6, string.format(“Tuning: %s done”, pname))
advance_stage(axis)
else
local new_gain = P:get()*get_gain_mul()
if new_gain <= 0.0001 then
new_gain = 0.001
end
adjust_gain(pname, new_gain)
if get_time() - last_gain_report > 3 then
gcs:send_text(MAV_SEVERITY_INFO, string.format(“%s %.4f sr:%.2f”, pname, new_gain, srate))
end
end
end
– wrapper around update(). This calls update() at 10Hz,
– and if update faults then an error is displayed, but the script is not
– stopped
function protected_wrapper()
local success, err = pcall(update)
if not success then
gcs:send_text(MAV_SEVERITY_EMERGENCY, "Internal Error: " … err)
– when we fault we run the update function again after 1s, slowing it
– down a bit so we don’t flood the console with errors
–return protected_wrapper, 1000
return
end
return protected_wrapper, 1000/UPDATE_RATE_HZ
end
– start running update loop
return protected_wrapper()
You are going to struggle with scripting with that board. Ideally need more memory.
Ok, Will abandon trying scripts. Thanks for your advice.
Greetings.
Using 4.4.3. Copter. To enable this to work does one have to install a seperate lua script on the sd card still. And if so where can I find the lua script
Yes, you need to copy the script to the SDCard on the vehicle.
The script documentation is here:
The script is here:
Is it Q-Autotune you want (thread title) or Quicktune?
Not sure what I am doing wrong.
Followed the ardupage and right clicked on the raw page, saved the file as a text file with .lua under the scripts folder on the sd card but not seeing quick_parameter in parameters
Have you enabled scripting?
SCR_ENABLE,1
You should really, really read:
I am following that.
The only thing I am doing differently is the tcal tuning as my FC has heated MCU’s and like i said previsouly I have never had any errors.
Then I am following @andyp1per’s guid on FFT tune as per his video.
The rest I am doing
FFT tune only works in 4.4
If you would have followed the instructions SRC_ENABLE would already be set to 1.
I followed the instructions and the paramters were set correctly
Andy i am on 4,4,3 currently
It would be q autotune
Really for Quadplane? You don’t need a script for that.
Sorry Quick autotune
