Hello everyone.
I’m trying to upload a GEOFence using pymavlink however I can not manage to do it. I looked at the forums and tried the code reference but still no luck. Can anyone help me find the issue?
I tried two different codes.
from pymavlink import mavutil
mav = mavutil.mavlink_connection('tcp:localhost:8100')
mav.wait_heartbeat()
print("Heartbeat from system (system %u component %u)" % (mav.target_system, mav.target_component))
points = ['four lat lon points']
for i in points:
mav.mav.command_long_send(mav.target_system, mav.target_component,
mavutil.mavlink.MAV_CMD_NAV_FENCE_POLYGON_VERTEX_INCLUSION, 0,
len(points), 0, 0, 0, i[0], i[1], 0)
This first one is a simple one using the MAV_CMD_NAV_FENCE_POLYGON_VERTEX_INCLUSION command from MAVLink however the SITL reply is: Got COMMAND_ACK: NAV_FENCE_POLYGON_VERTEX_INCLUSION: UNSUPPORTED
import time
from pymavlink import mavutil, mavwp
fenceloader = mavwp.MAVFenceLoader(mav.target_system, mav.target_component)
frame = mavutil.mavlink.MAV_FRAME_GLOBAL
for i in points:
fenceloader.add_latlon(float(i[0]), float(i[1]))
fenceloader.target_system = mav.target_system
fenceloader.target_component = mav.target_component
fenceloader.reindex()
action = mav.param_fetch_one('FENCE_ACTION')
mav.param_set_send('FENCE_ACTION', 0, 3)
mav.param_set_send('FENCE_TOTAL', fenceloader.count(), 3)
for i in range(fenceloader.count()):
p = fenceloader.point(i)
print(p)
mav.mav.send(p)
print(mav.recv_match(type='COMMAND_ACK', blocking=True))
mav.mav.fence_fetch_point_send(mav.target_system, mav.target_component, i)
tstart = time.time()
p2 = None
while time.time() - tstart < 3:
p2 = mav.recv_match(type='FENCE_POINT', blocking=False)
print(p2)
if p2 is not None:
break
time.sleep(0.1)
if p2 is None:
print("Failed to fetch point %u" % i)
if p2 is None:
if (p.idx != p2.idx or
abs(p.lat - p2.lat) >= 0.00003 or
abs(p.lng - p2.lng) >= 0.00003):
print("Failed to send fence point %u" % i)
mav.param_set_send('FENCE_ACTION', action, 3)
This second code is my best shot at replicating the MAVProxy implementation which is the one that is recommended in this forum.
However, this code gives me: AP: Invalid FENCE_TOTAL.
And the python console says: Failed to send fence point 0
Any help to solve this issue is appreciated.
Thank you in advance.
