Hello, Any real world cases someone would like to discuss of one battery fail with flight resumed on second battery? I have a dual battery system that I’ve been planning to hook up to a hex build I’m working on, but the whole thing and second battery is quite heavy relative to a single high capacity battery system of the same capacity. Is a dual+ battery system recommended for payload carrying multirotors in the 900mm size class? If I favor low weight and increased flight time for the build with a single battery system, what kinds of risk of failure numbers am I looking at? Thanks for the help.
How would that be accomplished? In a typical multiple battery system where they are in series or parallel if one battery fails it’s essentially the same as cells failing in one battery.
Oh well I might be completely misunderstanding the point of a system like this, lol, but I’m working with this: Mauch Premium Line Dual Battery Kit – Craft and Theory
Is the only benefit to a system like this capacity related?
Ideal diodes can used to do this quite efficiently (for packs that are in parallel). (There are other ways of course such as using a normal diode.) Allows the packs to drain from both batteries during use and can prevent charging of packs amongst themselves (such as the case of a failed pack).
Yes. That’s just 2 batteries in parallel with independent monitoring.
But what @hendjosh is suggesting is what you would want to look at.
That looks like a dual sensor only.
Mach has an ideal diode board but they aren’t big enough for a full copter amperage.
I’m not really sure of any readily available boards, but there is a user here selling them I think.
I was thinking that too but then realized I was thinking about @Artem_Skorsky power switch. Actually he does have a product:
Power module
Well thanks for this! Not sure what to say other than I misunderstood what I was doing here.
Thank you, this is very helpful. I really like the idea of this kind of redundancy, but struggling with the weight requirements. I’ll have to read up and see what can be done. Cheers.
