But the range on this parameter is 10 to 495. (according to the parameter list doc)
Looking at the parameters from an old copter I built a year or two ago - I had set this parameter to 30. So I’m wondering what to use in my current case.
Based on your other posts, it seems the link below is what you need (not the page you captured). My rule of thumb is hover freq / 2 (and typically not less than 20Hz).
You would be better off using the Filter Review Tool and testing it with estimated parameters. I don’t think many are still using Mission Planner for Notch Filter review.
If you have the time and interest - here’s the BIN file from the test flight - I’d be very interested to know anyone’s thoughts - to help me learn how to use this tool.
There’s an ever growing subset of tools that make things easier.
Don’t ignore the ones under development. They are reasonably complete but less thoroughly tested (or have features that are still rough around the edges).
It looks pretty good as configured. For some reason it’s not picking up the 1st mode X as best it can with a frequency of 55. 60 does it. And with that FC you can use Multi-Source with the same bandwidth. There is a 3rd harmonic but it’s down in the mud and as you configured it not worth adding a notch for. This is what I see as best by using estimated values:
And you need 1 for the reference. Actually, this is the reason the result with 55Hz was showing as I mentioned. You can leave it at 55 with the right reference value.
Of course. But the wiki is the ArduPilot “front door”.
In fact, the reason I didn’t know about the Filter Review Tool is because it’s not mentioned in the wiki’s sections on notch filters. It’s only mentioned in the section about troubleshooting.
Have you considered making a video that illustrates using your tool?
I’m all about using proper tools to achieve goals. And the only reason I haven’t spent time with your tool is because I’m not familiar with it, and I couldn’t justify the time to learn it.
If others are in the same situation, a video may help people decide to use your tool.
