I have a problem with sides. When i have changed position of drone YAW, pitch change on roll. If i need pitch is pitch i need turn left or right my drone. So only on one position work right. I dont understand. So help pls.
Sounds to me like you activated Simple Mode.
i have stabillized mode.
Post a link to a .bin flight log and describe the craft and it’s components.
how can i do it because i have used AP 2 weeks, so dont know?
1st you can start with a simple Google search that will lead you to the Arducopter Wiki page for the topic of interest. Searching “arducopter logs” will do it.
I’ll give you the link this time; next time try it yourself 1st and then ask for help if you need it:
Downloading logs
As you progress I would suggest you answer all questions asked. There were two, .bin logs were one of them.
ok. I will try. thank you
