Problem with custom command in AutoMode
Hello!
I’m trying to create a new command for the AutoMode in ArduCopter.
So far I successfully created a new MAVLink command.
Also I added two new functions do_mycommand(…) and verify_command(…)
I created a new mission file with my custom command as a last entry.
The problem I now experience is:
In do_mycommand(…) I want the drone to fly to a specific point, therefore I call copter.wp_nav->set_wp_destination(…);
do_mycommand(…) is executed but verify_mycommand(…) is never called and also the drone is not flying to the specified position. It just stands stills. If I add another command after my custom command in the missions file, verify_mycommand is executed, but my request from set_wp_destination is ignored, the drone strictly executes the command with the specified parameters from the mission file.
Am I missing something? Is it not possible to add a new waypoint the drone should fly to during an active mission? If not, what are my options?
After reading the code extensively, I figured out, that I have to “mark” my command as a nav command, because do commands are executed in parallel with the next nav command?
I achieved this by adding a new condition check in the function
bool AP_Mission::is_nav_cmd(…)
in AP_MIssion.cpp
In my opinion this is not quite convenient. Are there better ways?
