Did you read through this discussion ?
Check you’ve got the correct version firmware installed and set the baro option
im also have same prablum
What version are you using?
I’m currently using matek 743
I change fmuv3 to Pixhawk 1 for Pixhawk 2.4.8 flight controller and drone is working well.
well, thanks this worked with me too. the thing left with me is the GPS altitude variation is going crazy including the vertical acceleration I’m using ublock m8n
