I get the error message “Prearm: ahrs: ek3 sources require GPS” and cannot arm my drone despite it arming fine before the upgrade to 4.4.2. My compass works and I get GPS lock and GPS home set. I attach my params. Should I provide a log file while disarmed too? I’d be really grateful for some help to work out why it’s not arming. Thanks.
I have news! The problem is due to Arducopter and nothing to do with my hardware.
I tested various firmware versions and found that I had no baro problems with 4.3.8. As soon as I upgraded to 4.4.0 I see this error message:
“Bad Baro Health”.
You’ve already seen the error I get with 4.4.2 which is similar. BTW, the title of this thread is wrong - there is no GPS problem in any firmware.
I read the 4.4.0 release notes and lo and behold, Arducopter is no longer compatible with my board because I have a DPS310 barometer and now the firmware only supports BMP280 “to reduce code size”. This is pretty crap.
I suppose I’ll have to try and compile my own firmware with this feature enabled.
It doesn’t arm. I haven’t checked the full log yet but I’m 99% sure the abreviated message on my Taranis was the same as with 4.4.2. i.e. barometer not working
