Pre arm: logging failed during imu temp. calibration
Ran the imu temp. calibtation as the methodic configurator suggests, unfortunatelly, after getting the f.c. out of the freezer and connecting it to the the pc the ‘Pre arm: logging failed’ message poped out.The sd card was working fine before that,could it have been damaged ?should i had removed it and dry it before connecting the f.c. to the pc??
You are not supposed to conect it to the PC.
The methodic configurator instructions clearly tell you to connect it to a battery.
Thank you very much for the quick responce🙏
