Powering the RasPi 3
I have seen in a few videos where the RasPi3 is powered from the Pixhawk Telemetry port. Granted it was bench testing, but is it wise to power the RasPi this way?
Thanks
Absolutely not. You’re pretty much guaranteeing that you’ll cause a brownout of the flight controller and will crash. Never, ever do this :slight_smile:
Power the pi from a BEC. I attach the BEC output to the power rail of the pixhawk outputs, then I power other things like the raspberry and landing gear from this rail.
I had my doubts, I wasn’t sure how much current I could source from the telemetry port connector, but I doubt it is the full required for the RasPi
THANKS!
Depends on the flight controller I would say. On apm 2.8 there is just a 5v+ rail coming from the power module. So if that can take the load, then why not…
@fnoop. Glad to see this answer. I have powered by pi via telemetry as it was shown in raspberry-pi-via-mavlink and both pi and pixhawk2.1 shutdown and die. I will try your recommended approach.
