Some of those have XT60 connectors to the battery, so, thats the limit, no matter what they say about the board.
That may improve if you add XT90 or higher capacity battery connector.
The cable diameters being used max out at around 90A anyway, even if the battery is rated at 500A the cables typically attached won’t handle much more than 90A for any extended period.
A comment on the designs - every connector in your electrical system is a potential failure point.
Those companies are just quoting the conductive capabilities of the copper, nothing else, and even then its doubtful.
For a PDB I use a similar design to the one you have pictured
and directly solder to the board.
