Firmware version: 3.5.2
Airframe - X-UAV Talon
Flight controller - 3DR Pixhawk
I was tuning the aircraft in AUTOTUNE
mode, and the canopy flew off the aircraft mid-flight. I proceeded to land the aircraft and began the approach. After a short while, I noticed that the plane was no longer in my control. Mission planner showed the plane to be in AUTO
mode. By the time I could switch back to FBWA
and try to regain control, the plane had overturned and it crashed. I also noticed that the plane didn’t respond to my input in FBWA
either.
I checked the logs to see what could’ve gone wrong, and found that there was a brief period in the log where the dataflash log had recorded no sensor data. That period contained only ORGN
and ATRP
messages. The logging resumed when the plane switched the mode to AUTO
. After the switch to AUTO
, the dataflash contained only about 2 seconds of logged data.
I checked the telemetry log and it paints a weird picture. The HUD showed (SAFE)
which I’ve seen happen when the hardware safety switch is pressed. which clearly didn’t happen mid-flight. Following that, there was no dataflash log. The plane switched to AUTO
, rolled right, and went beyond the LIM_ROLL_CD
specified angle of 45 degrees. The Tlog also showed the altitude at that point to be 0. But the plane was still in the air! When the plane crashed, the Tlog showed an altitude of - 37m.
I’m thinking that the pixhawk or one of the sensors failed mid-flight. Is an open canopy with oncoming air at 15m/s not good for the pixhawk?
I also noticed that the ORGN
message was being updated in the period where there was no logging. The home position was being updated very rapidly from the original position to a new position. What could cause the location to be updated like that?
What cause the (SAFE) message to be displayed? What could have caused the pixhawk to have stopped recording?
This seems like a very weird crash, unlike any I’ve ever seen before. I’d love if some of you would have a look at this and give their thoughts on this.
EDIT: forgot to attach the flight log - https://drive.google.com/file/d/0B-NIddUSff_hSVFDdWxwT3MyNUk/view?usp=sharing
Thanks,
Nihal
