Hello everyone, I have a high level path planner in ROS that I would like to use on top of ArduCopter.
I know that I can communicate from my ROS node and Mavlink with mavros.
My high level planner spits out position, velocity, and attitude (represented as quaternions) trajectories.
There is SET_POSITION_TARGET_LOCAL_NED which allows me to send position and velocity setpoints. There is also SET_ATTITUDE_TARGET which allows me to send the quaternion setpoint.
However, I would like to send all three (pos, vel, and att), over Guided Mode. Is this currently possible?
In SET_POSITION_TARGET_LOCAL_NED you’ve got yaw control, but if you look at the AC_PosControl design (https://ardupilot.org/dev/docs/code-overview-copter-poscontrol-and-navigation.html) it’s just a stack of PID controllers. I don’t think it’s able to handle some fancy paths from open loop planner. I think you should put some MPC controller in ROS to follow the global path and use only low level AC_AttitudeControl
Yeah thinking a bit more about, you’re right. Sending pos and vel setpoints to Ardupilot won’t allow me to do fancy maneuvers. Maybe sending just attitude and thrust would be the way to go?
I actually currently have an MPC controller in ROS which outputs angular velocities and thrust.
Ideally I would like to have a mode where Ardupilot allows me to send angular velocities and thrust as setpoints.
Since I can’t do this, without adding my own controllers in the mode_guided.cpp file (maybe I should just do this), I am going one step “higher” and trying to send the corresponding pos, vel, att states based on my model.
I’ll continue looking deeper in the attitude control, and see how I can expose that functionality through mode_guided.cpp so that there is a connection between mavros and Ardupilot for that part of control.
Exactly! Current control is designed for missions of type fly straight from A to B, rotate, fly B to C
I even investigate that MPC topic recently and I think it’s doable (attitude + thrust) but I didn’t have time to finish it. Let us know what you get. In case you stuck I can dig in my notes
For sure, I’ll keep this thread updated with my progress. Once I start concretely working on it I’ll share a link to my fork of ardupilot. Wanna do some architecture design first.
I think right now, I’ll start with modifying mode_guided.cpp and slowly adding unraveling layers of API.
One of lowest levels would just be motor outputs, which is what the AttitudeControl outputs (I guess low level controllers that output moments would like this API)
One layer above that would be angular rates and thrust (which is what most “mid” level controllers would be interested in.
I don’t think you have to change much in guided. Look into angle_control_run(), recently thrust control was added there and that is pretty much it. You’ve got there AC_AttitudeControl instance that is responsible for lower level pid control.
I’ve been using SET_ATTITUDE_TARGET in guided mode and although I can orient the craft where I intend, the position controller slowly drifts away even when no position change is commanded (yaw only attitude change). @acxz Have you experienced this?
I actually haven’t had time to test SET_ATTITUDE_TARGET yet, I’ll probably get around to it during Thanksgiving week and let you know (no guarantees tho…)
Hi vdot, I have recently been testing SET_ATTITUDE_TARGET and the drone does fly away, at least when commanding a yaw attitude. Please see my post here for videos.
