Hi, I’m really new to Ardupilot. I’m trying to determine the reason why the GPS Glitch occured. But I still can’t find it.
Here’s my LOG file
https://drive.google.com/file/d/1UpT97S4wDabHyHiHli7s5FvCW9YzXg0j/view?usp=sharing
Thank you in advance for your helps
For some reason your vcc becomes very noisy at times, everytime it becomes noisy you have a gps glitch. Probably should check 5v power to the board and accessories.
Hi, thank you so much for the prompt response.
Could you tell me how to check the VCC value?
vcc is in your log under POWR label.
Ah, I see. Thanks so much.
May I ask which values should we check first when GPS glitch was occurred?
I’m wondering how could you find out that it’s from VCC . It’s really right! I’ve just found that one my power board doesn’t work proberbly.
I just looked a bit around your log. i checked if there was any power issues with gps module so i checked the vcc power and i found that the graph was noisy each time there was a glitch
