I think you are correct → use the MOT_THST_HOVER, and from the graph it looks like you would use 70Hz (the next big spike up is about 140Hz)
You current params file doesnt have HNOTCH enabled.
You can go to “Phase 2” in my cheat sheet and use these values
INS_HNTCH_REF,0.15
INS_HNTCH_FREQ,70
INS_HNTCH_BW,35
This is my own cheat sheet for setting up the Harmonic Notch filter
=========== Using throttle ============
HNOTCH phase 1
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,0
- hover test >1 minute, check FFT
HNOTCH phase 2
INS_HNTCH_ENABLE,1 ← set this then refresh params to see the rest
INS_HNTCH_MODE,1
INS_HNTCH_REF, hover_thrust
INS_HNTCH_FREQ, peak freq from FFT
INS_HNTCH_BW, peak_freq / 2
INS_HNTCH_ATT,40
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,2
- hover & dynamic test >1 minute, check FFT results
HNOTCH phase 3
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
- no extra logging, assumes HNOTCH is working great
BUT forget all that stuff above…
You appear to have DSHOT configured and working on Aux outputs. You just need the ESC telemetry wire connected to a serial (TELEM) port RX pin and set something like this:
SERIAL2_OPTIONS,16
SERIAL2_PROTOCOL,16
then set these and go run Autotune
============= Using ESC Telemtry ============
HNOTCH BLHeli32 telem
INS_HNTCH_ENABLE,1
INS_HNTCH_MODE,3
INS_HNTCH_REF,1
INS_HNTCH_FREQ,70
INS_HNTCH_BW,35
INS_HNTCH_ATT,40
You can set these and view the FFT graph to check if it’s working OK
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,2
and when satisfied, set these:
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
