My rambler RS crashed due to vibZ high.
For the aircraft landing with the belly, it is inevitable that there will be a little wear and tear on the propeller. If the wear on both sides is consistent, the vibration value will not be increased, but if the wear on both sides is inconsistent, the vibration value will increase. Can our system add three axial vibration parameters on the OSD page so that it is easy to monitor. Once I see the vibration value slowly getting bigger, I can replace the propeller in time, because I do not use telemetry radio,it interference with video trsnsmitter
