Planning my first plane build
I am new to Ardupilot are currently planning to build my first Plane. In 2019 I have built a 7" Quadcopter and wanted to move it from iNav to Ardupilot. But it seems that the Omnibus F4 I have (a RotorRiot Riot control F4) is to old for running Ardupilot.
The plane I want to build is the 3D printable picoTalon from Flightory.
For the RC Link I use a Jumper T16 Pro and a TBS Crossfire TX (full size with Wifi module and Bluetooth).
For the electronics I put a list together. Please give me your thoughts on the selection.
  • Matek H734 V3 Wing
  • TBS Crossfire Nano Diversity RX
  • TBS Crossfire Immortal-T V2 Extra Extended
  • T-Motor F35A ESC
  • T-Motor F90 28065 Long Range 1300KV
  • Matek 3901-L0X Lidar Sensor
  • Matek ASPD-4525 Digital Airflow Sensor
  • Matek AP Periph DroneCan GNSS M10Q-3100
  • TBS Unify Pro32 DP Heat Sink
  • TBS Unify Pro32 DP (MMCX)
  • Caddx Ratel 2 - 2.1mm (Black)
  • Corona 929MG Metal Gear Servo 2.2kg / 0.10sec / 12.5g
  • Corona CS-239MG Slim-Wing Analog Servo 4.6kg / 0.14sec / 22g
  • Battery Li-on 21700 4S1P 5000mAh or any around 300g
I have no knowledge about Servos and find it quiet the steep learning curve to get into. I just took the suggestion from the Flightory Team.
For the battery I am still not sure how I will do it. Either a DIY LiIon Battery or a bought LiPo that fits the suggestion of the Flightory Team.
I have already read through the Wiki and a lot of post on this Forum.
Kind regards,
Nathan
