Plane was flying in auto mode but it suddenly cut off the throttle. It took no damage after after crash but I did not understand the problem. Esc and motor are working properly. I tested them after crash. Log file is attached. Do you have you any ideas?
log files:
The log shows SERVO3 (RCOU.C3), the throttle, being commanded all the way during the decent. Meaning the flight controller was sending the signal to the motor to keep spinning. But the descent suggests it wasn’t getting the message. Check wiring for both power and signal to the ESC.
Also, since there is no voltage monitoring, check that your battery voltage was enough. Maybe there was an ESC low-voltage cut off.
