Hi, this is my log file.
I have just released plane 4.4.3. Changes from 4.4.2 are:
- fixed setup of ICM45486 IMU on CubeOrangePlus-BG edition
- disable AFSR on IxM42xxx IMUs to prevent gyro bias for “stuck” gyros
- fixed AK09916 compass being non-responsive
- implement GPS_DRV_OPTION for using ellipsoid height in more GPS drivers
- fixed SIYI AP_Mount parsing bug
- configuration fixes for BETAFTP-F405 boards
- fixed origin versus home relative bug in quadplane landing and guided takeoff
- correct mavlink response for no airspeed sensor on preflight calibration
- protect against notch filtering with uninitialised RPM source in ESC telemetry
- allow lua scripts to populate full ESC telemetry data
- added YJUAV_A6SE_H743 support
- fixed uBlox M10 GPS support on boards with 1M flash
Happy flying!
I have had a look and see the log ends in flight. Some questions:
- I note that this is not a flight controller we support in ArduPilot. I see you have an open PR to add this board here: Support for ElfinH7 Wing by suiaiyun · Pull Request #24543 · ArduPilot/ardupilot · GitHub - we should try and get that merged in
- can you please find the tlog (telemetry log) for the flight on the GCS - that may offer us some clues as to what went wrong
- can you tell me what telemetry radio you are using? It is logging RAD messages which would imply SiK or RFD900, but the RemNoise field is always 255 which is very strange
- the firmware is 4.4.0, but we did not support the H750 with CAN in 4.4.0. I see you have backported the changes, which should work, but means you are running untested code
- it isn’t clear to me how you are doing parameter storage on this board? The hwdef.dat does not seem to define any mechanism
Hopefully the tlog will give us some clue as to what went wrong.
During the flight, I used the mobile version of QGC, and by default, I did not save the tlog log. I also did not find it on my phone’s memory card.
The remote control I am using is MLRS, which supports Mavlink data transmission, similar to the remote control of Siyi.
The firmware version I am using is 4.4.0. I tried to compile 4.4.2 and it was successful, but it did not run successfully on my flight control. It stopped at the bootloader jump. (I set the parameter “FLASH_SIZE_KB” to 2048 to include all the functions.)
The parameters are saved on the tf card, in a file called arduplane.cfg.
There is a random issue: there is a probability of getting stuck in the bootloader jump during the startup process and not being able to enter the flight control system normally. I don’t know if this accident is related to this.
@tridge Hello, I was using the firmware 4.0.7 for my quad plane and it was flying perfectly during quad mode. I updated the firmware to 4.4.0. The plane started to shake during take-off and also during landing, which led to it falling several times. Is there a major change in the parameters? Was the code causing the problem, or what?It was all the crashes that happen to the plane during landing, Unfortunately, I stored the log in the memory that crashed together with the plane crash. The remote measuring device I am using is not compatible with the mission, but I have the parameters that were on the plane. My problem is with the code parameters only. I downloaded the parameters that were in version 4.0.7 to The parameters in version 4.4.0 and I did not change any of them, but I saw that with the new version 4.4.0 during landing my plane was unable to balance and then failed to land. These are the parameters that I used.As for the rear throttle, I turn it off using the command DO_REPAT_SERVO just before the landing point.
Looking forward to the 4.4.4 update.
I’ve just released plane 4.4.4-beta1.
Changes from 4.4.3:
- CubeOrange Sim-on-hardware compilation fix
- RADIX2HD supports external I2C compasses
- SpeedyBeeF405v4 support
- DroneCAN battery monitor with cell monitor SoC reporting fix
- ProfiLED output fixed in both Notify and Scripting
- NTF_LED_TYPES parameter description fixed (was missing IS31FL3195)
- Scripting bug that could cause crash if parameters were added in flight
- STAT_BOOTCNT param fix (was not updating in some cases)
- don’t query hobbywing DroneCAN ESC IDs while armed
- clamp empy version to prevent build errors
Please test!
@ tridge
There is a problem that I am facing with Firmware 4.4.0 due to the value of max_t (main loop rate). I connected to the Cuav v5+ system via the com port (USP), and I ran the system with version 4.4.0 and set the parameters to default after I activated q_enable, also the value SCHED_LOOP_RATE is 300, which is the default value. I made the system run for a while, switching modes, then I analyzed the .bin record attached below, and I saw that the value of max_t = 5 and 4.5, and the correct value for it is 3.3ms. This problem did not appear to me when I was using version 4.0. 7. What is the solution please?: 00000001.BIN - Google Drive
and This is another log,Together form 4.4.3 It’s the same problem:
and This is another log with the 4.0.7 Firmware and its default parameters, also with the same steps q_enable = 1 and SCHED_LOOP_RATE = 300, it was connected to the system via com (USP), and with the same system used for 4.4.0 Cuavv5+, it is noted that the value of max_t here is at 4.0 .7 equals 3.3ms.
@trag123123 I just tested a CUAVv5 with 4.4.4 and I do not see any scheduling errors when I load the parameters from your log. Please re-test with 4.4.4.
Note that you can see scheduling errors without downloading the log file by setting SCHED_DEBUG=1 and looking in the messages tab. This is what I see:
AP: PERF: 0/1500 [3446:3209] F=300Hz sd=11 Ex=0
AP: PERF: 0/1500 [3420:3245] F=300Hz sd=10 Ex=0
AP: PERF: 0/1500 [3463:3203] F=300Hz sd=10 Ex=0
AP: PERF: 0/1500 [3419:3247] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3495:3169] F=300Hz sd=14 Ex=0
AP: PERF: 0/1500 [3410:3258] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3432:3234] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3424:3235] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3439:3227] F=300Hz sd=10 Ex=0
AP: PERF: 0/1500 [3434:3232] F=300Hz sd=10 Ex=0
AP: PERF: 0/1500 [3458:3210] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3454:3216] F=300Hz sd=12 Ex=0
AP: PERF: 0/1500 [3454:3214] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3422:3244] F=300Hz sd=10 Ex=0
AP: PERF: 0/1500 [3416:3250] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3413:3257] F=300Hz sd=11 Ex=0
AP: PERF: 0/1500 [3426:3240] F=300Hz sd=11 Ex=0
AP: PERF: 0/1500 [3469:3200] F=300Hz sd=11 Ex=0
AP: PERF: 0/1500 [3413:3250] F=300Hz sd=9 Ex=0
AP: PERF: 0/1500 [3465:3198] F=300Hz sd=11 Ex=0
this shows no long loops (0/1500) and a small loop standard deviation
I’ve just released ArduPilot plane 4.4.4. Changes from 4.4.3:
Happy flying!
Fine, thank you
Cheers, Tridge
Had some very weird EKF3 behaviour because of GYRO data corruption. Please have a look at my thread:
Hello, I used plane 4.4 to fly the quadplane On the first flight, the route moved at a low frequency in roll. After the flight landed, I modified the ff and p of roll, and modified the ff and p of pitch. When I took off again, the plane hit a tree. Yes, the elevator is invalid. I speculate that the ff of the pitch should be increased to be correct. I would like to ask if the new pid has a greater weight on ff. P only affects the speed of reaching the angle.
Good day everyone. I have had issues since I updated to 4.4.4 quadplane firmware on my MFE striver equipped with Pixhawk 6c and f9p holybro. Before i’ve been updated from 4.3.7, everything was working fine, but now when I’m trying to takeoff in QHOVER manually vehicle starts to spinning by YAW axis and performs unstable hovering causing a crash. Everything was recalibrated and still have no result.
Hello Tridge,
Wondering if you’d have some time to review the dataflash log from my recent quadplane flight that ended up in a crash. I have a video of the crash as well that can further help analyzing what went wrong. Let me know and I will upload both the log file and video for your kind advice.
Thanks
Regards
Osman
This was the first post by your user ID on this forum, so I don’t know how to find the log or crash report you are referring to. Where did you post it?
