I’m delighted to announce the ArduPilot plane 4.3.0 stable release! This is a major release and is the first major release on our new 6 month release cycle.
If you have been following the 4.3.0beta releases then you will know there have been a lot of changes from the last 4.2 release. Since 4.3.0beta3 there have been only 2 changes:
- added 1M and 2M flash warning checks for for fmuv2, fmuv3 and Pixhawk1-1M firmwares
- added support for multi-byte i2c reads in scripting
Since 4.2.x there are a huge number of changes, but these are the key ones:
- fixed BRD_SAFETY_MASK for enabling outputs when safety on
- fixed persistence of mapping of CAN airspeed sensors to instances
- fixed precision of NMEA serial output function
- added report of “Engine Running” when using ICE
- fixed handling of defaults.parm files with lines over 100 chars
- fixed handling of defaults.parm files with no newline on last line
- fixed possible divide by zero when changing to GUIDED on quadplanes
- fixes for VideoTX, fixing buffer overrun and tramp handling
- fixed spurious error about sending RPM when RPM disabled
- fixed an EKF3 lane switch issue that can cause incorrect height with dual GPS
- fixed mission cmd to mission int initialisation error
- fixed mission jump tracking init on startup
- fixed OSD view roll/pitch error for tailsitters
- added SkystarsH7HD-bdshot
- fixed SkystarsH7HD VTX control
- reduced memory usage on MatekF405-CAN board
- disable SLCAN when armed to reduce CPU load
- enable CAN battery mon on CUAV V6X by default
- added arming check for Q_M_SPIN_MIN value too high
- fixed reporting of RPM from harmonic notch
- improved handling of airspeed errors and airspeed auto disable
- fixed SERVO_AUTO_TRIM for multiple outputs of same type
- fixed auto baud rate detection on SBF/GSOF/NOVA GPS
- increased max board name length for mavlink statustext to 23
- fixed incorrect disable of notches for non-throttle notch
- added notch filter slew limit to reduce notch errors
- added ARMING_OPTIONS to control display of pre-arm errors
- several OSD fixes for params, font and resolution
- support PWM type transmission for CAN PWM output
- support Currawong ECU as EFI backend
- support lua scripts for EFI backends
- implement SkyPower and HFE CAN EFI lua scripts
- improved speed of log download with dataflash block backends
- disabled all GPS drivers except uBlox and NMEA on Pixhawk1-1M to save flash
- disabled all GPS drivers except uBlox on MatekF405-bdshot and omnibusf4pro-bdshot
- fixed FFT indexing bug
- added USART2 for AIRLink
- allow reset to default airspeed using mission item DO_CHANGE_SPEED
- added new boards AtomRCF405, KakuteH7Mini-Nand, SkystarsH7HD
- added bi-directional dshot for several new boards
- EK3_GPS_VACC_MAX threshold to control when GPS altitude is used as alt source
- EKF ring buffer fix for slow sensor updates
- EKF3 source set change captured in replay logs
- numerous gimbal support improvements
- improved RemoteId support
- SecureBoot support with remote update of secure boot public keys
- crash_dump.bin file saved to SD Card on startup (includes details re cause of software failures)
- several new pre-arm checks (AHRS type, scripts, terrain)
- numerous scripting improvements
- fixed scripting restart leaking memory
- Benewake H30 radar support
- BMI270 IMU performance improvements
- Logging pause with auxiliary switch
- TeraRanger Neo rangefinder support
- support for both AMSL and ellipsoid height in most GPS drivers
- Custom controller support
- parameter defaults sent with param FTP and onboard logs
- Sim on Hardware allows simulator to run on autopilot
- added Q_LAND_ALTCHG parameter
- added climb before QRTL for safer QRTL from low altitudes
- added support for logging pre and post filtered FFT data
- support triple-notch harmonic notch filter
- support up to 32 actuators (with SERVO_32_ENABLE parameter)
- support EFI input over DroneCAN
- by default only run notch filter on first IMU
- added ESC_TLM_MAV_OFS parameter for mapping ESCs to MAVLink ESC telemetry
- added Q_NAVALT_MIN for quadplane takeoff
- added ICE redline governor
- added in-flight FFT notch tuning option
- added Sagetech ADSB support
- added INS_HNTCH_FM_RAT parameter for handling under-hover throttle
- improvements to filtering on ICM42xxx IMUs
- added option parameters to NAV_VTOL_LAND mission item for fixed wing approach
A huge thank you to everyone who contributed to the 4.3.0 release! We have had a lot of testers and a lot of input from ArduPilot partner companies, both in terms of testing and suggestions for new features.
A big thank you also to everyone who has contributed to the documentation which has involved a lot of work. Special thanks to @hwurzburg for his tireless work on the wiki!
There are a couple of things in the pipeline for later 4.3.x releases which we are still testing, but we are very happy with how 4.3.0 has turned out.
Happy flying!
