tridge
(tridge)
October 19, 2022, 2:32am
22
I’ve just released plane 4.3.1beta1. This is a minor update with some useful enhancements and fixes:
fixed build with gcc 11.3
fixed random number generator in lua core
scale VTOL angle P with airspeed in quadplane back-transiton
added support for implementing AUX functions in lua scripts
fixed BMI085 accel scaling
fixed KSXT NMEA parsing affecting position resolution
fixed race condition in TECS control leading to ‘nod’ in forward transition
allow for expansion of notch filters to fix notch of fwd motors in quadplanes
added logging of TECS target alt
In case you are not familar with loading beta releases, this is how to do it with MissionPlanner:
Please test and report back!
MartyMcFly
(MartinKeilloh)
October 19, 2022, 6:58am
23
Sterling work as all ways Tridge,thank you
xixijoe
(Xixijoe)
October 19, 2022, 8:17am
25
@andyp1per it is Matek F405wing
andyp1per
(Andyp1per)
October 19, 2022, 8:55am
26
Ok, here is a build with tramp debug turned on for Plane 4.3. Unzip it and upload the apj to your board using mission planner:
arduplane.zip (651.8 KB)
To see the debug you will need to use mavproxy - MAVProxy — MAVProxy documentation - please try it and show me the console output.
aeolus
(Maarten)
October 19, 2022, 9:11am
27
4.3 No problem so far. Thanks.
xixijoe
(Xixijoe)
October 19, 2022, 2:18pm
28
I am sorry I don’t how to use mavproxy. here is what I get.
MAV> Traceback (most recent call last):
File “site-packages\mavproxy-1.8.6-py3.5.egg\MAVProxy\modules\lib\wxconsole_ui.py”, line 52, in on_menu
File “site-packages\mavproxy-1.8.6-py3.5.egg\MAVProxy\modules\lib\mp_menu.py”, line 66, in call_handler
File “site-packages\mavproxy-1.8.6-py3.5.egg\MAVProxy\modules\lib\mp_menu.py”, line 280, in call
TypeError: object of type ‘map’ has no len()
andyp1per
(Andyp1per)
October 19, 2022, 2:45pm
29
Are you on windows? Did you use the .exe installer?
xixijoe
(Xixijoe)
October 19, 2022, 3:38pm
31
yes mine os is windows 10. installed under program files X86. run Mavproxy. while 405wing connected to Mission planner. run Mavproxy, the white window pops then click Mavexplorer then click Open. then I got info on the black window.
andyp1per
(Andyp1per)
October 19, 2022, 10:04pm
32
You need to do “add link”:
xixijoe
(Xixijoe)
October 20, 2022, 1:03pm
33
when I click Mavproxy. here is what the blackwindow showes,
Auto-detected serial ports are:
COM3 : ArduPilot (COM3) : USB VID:PID=1209:5741 SER=45003D0008504D4254393920 LOCATION=1-1
Connecting to COM3 : ArduPilot (COM3) : USB VID:PID=1209:5741 SER=45003D0008504D4254393920 LOCATION=1-1
Connect COM3 source_system=255
Running script (C:\Users\Jazzplane\AppData\Local\MAVProxy\mavinit.scr)
Running script C:\Users\Jazzplane\AppData\Local\MAVProxy\mavinit.scr
→ set moddebug 2
→ module load help
Loaded module help
Unknown command ‘graph timespan 30’
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from COM3
MAV> online system 1
RTL> Mode RTL
APM: ArduPlane V4.3.0beta1 (219ad27d)
APM: ChibiOS: 75a01029
APM: MatekF405-Win 003D0045 424D5008 2039395
APM: RCOut: DS150:1-2 PWM:3-10
APM: IMU0: fast sampling enabled 8.0kHz/1.0kHz
Flight battery 100 percent
APM: PreArm: 3D Accel calibration needed
APM: PreArm: Compass not healthy
APM: PreArm: GPS: waiting for home
APM: PreArm: Radio failsafe on
Received 1108 parameters
Saved 1108 parameters to mav.parm
andyp1per
(Andyp1per)
October 20, 2022, 1:10pm
34
Ok, can you try doing this immediately after the board boots to see if there is any tramp output?
xixijoe
(Xixijoe)
October 20, 2022, 1:23pm
35
OK,this is what i got
Loaded module graph
Loaded module console
Loaded module map
Running script (C:\Users\Jazzplane\AppData\Local.mavproxy\mavinit.scr)
Loaded module help
Log Directory:
Detected vehicle 1:1 on link 0
Received 1108 parameters (ftp)
Saved 1108 defaults to defaults.parm
andyp1per
(Andyp1per)
October 20, 2022, 1:29pm
36
Can you post your full parameter set
xixijoe
(Xixijoe)
October 20, 2022, 1:31pm
37
yes sure. please check it.
andyp1per
(Andyp1per)
October 20, 2022, 1:34pm
38
There is no tramp setup in those parameters
xixijoe
(Xixijoe)
October 20, 2022, 2:19pm
39
sorry,I did not do param restore after the firmware flashed you sent to me. I have done it check it pls
andyp1per
(Andyp1per)
October 20, 2022, 2:22pm
40
Ok, please now do the mavproxy test again
xixijoe
(Xixijoe)
October 20, 2022, 2:41pm
41
Do i need to power the FC with the battery or only USB cable power. is VTX needs to be connected if it is battery powered?
andyp1per
(Andyp1per)
October 20, 2022, 2:43pm
42
VTX needs to be powered. Most VTX’s require battery power to work - but not sure whether yours does
