Hi Tridge, I have been working with Mark Whitehorn to get his PR for forward tilt using the elevator stick, based on ArduPlane 4.2 Beta. We got it to work in the SITL Convergence model, and in my 1/6 scale model of my flying car with a Mini Pixfalcon. But we ate still have a problems getting it to work in my full scale vehicle with a Pixhawk Cube Orange. The 1st problem we solved was getting the ESCs to work. It turned out the PWM min and wax values was somehow reset to 0. The ESCs began working once the PWM min and max values were set to 1000 and 2000 respectively.
It seemed like everything was working ok. So we test hovered the vehicle indoors and the vehicle crashed due to a huge oscillation in pitch that developed as I pitched the vehicle to move forward. During this test Mark’s tilt forward using the elevator stick feature was disabled using a ch 6 switch, making the vehicle supposedly fly like it did before (elevator controled vehicle tilt to move forward). I have just finished repairing the vehicle and now I am trying to find out what caused the oscillation in Pitch. Here is a video of the crash:
So today I placed a beam under the vehicles CG enabling the vehicle tilt up and down, and fired up the motors a little to study the stabalization. The results looked strange to me. I monitored Pitch and Nav_Pitch signals and noticed that they track nicely if I physically tilt vehicle up and down. But when I fired up the motors the Nav_Pitch railed to zero! This surprised me because. But Mark thinks this is ok.
Here is a picture of the Nav_Pitch and Pitch signals. Note the signals track very well when the batteries to motors are not connected. But as soon as the batteries to the motors are connected and the throttle is applied, the Nav_Pitxh signal rails to zero:
Here is a link to see a video of the previous test flight before we changed to ArduPlane 4.2 Beta using Mark’s elevator stick controlled tilt forward PR:
more useful than video would be the log of it flying with the previous version but the same parameters, then a log of it not flying well with 4.2 with those same parameters.
Hi Tridge, Below is the log corresponding to the good flight video before the change in firmware. The firmware used in this flight was ArduPlane 4.0.9. The log file is called 189.bin. and the last flight corresponds to the good flight in the above video:
I compared the flight log signals of the good flight and the crash flight. In the crashed flight log I am seeing a huge oscillation in the P of the Pitch PID controller. I think the Pitch P param needs to be lowered. Here is a link to see the 2 log files compared. The thing to notice is the scaling of the Pitch and Des_Pitch in the 2 graphs.
you can see poor pitch control, with little relationship between demanded and achieved pitch angle. The total pitch deviation isn’t as large as it is with 4.2, but it is not in good control.
In 4.0.9 (as with the 4.2 log) I see the pilot providing considerable input to hold the vehicle steady. If stability is good this should not be needed.
Have you considered suspending the vehicle by a rope from the CoG until you get good control? You could suspend it so only pitch axis can move.
Then you would do this:
raise D until it oscillates, then reduce till it stops oscillating, then halve
do the same for P
If this fails to produce a good responsive pitch tune then you need to adjust filtering and acceleration limits. I notice your accel limits are still at defaults (Q_A_ACCEL_P_MAX is 110000). That is likely way too high for this vehicle. You also haven’t set Q_A_RATE_P_MAX, which likely should be 45 deg/s or so for this vehicle. Same for other axes.
I hope this helps!
The large pitch oscillation was caused by the D parameter of the Pitch PID being too high. When I changed from D=0.01 to D=0.001 the large oscillation went away. I was also able to increase P to from P=1.0 to P= 1.8 before I saw heard the motors oscillate. So I reduced it to P= 1.4 for the test. I noted a little oscillation at D= 0.005, so I reduced it to D= 0.001 for the test.
I tested the vehicle by placing a narrow board under the vehicles side panels at the CG with the motor batteries mounted in the front of the side panels. The vehicle was about level when I tested it and it could pitch up and down about 5in as seen at the back end of the vehicle.
In the test, I am testing Mark’s new PR (4.2 Beta) with the elevator stick controlling the forward tilt of the front motors. But back elevator stick tilts the vehicle back. The motors tilt correctly and the pitch seems relatively stable (other than the usual small angle oscillation always present) during the tilt. Pulling back on the elevator pitched the vehicle up until it hit the ground, preventing the vehicle from responding to more pitch.
Blue - Elevator stick
Red - Pitch
Green - Desires Pitch
Yellow - Motor tilt
There seems to be something unexpected happening in this release for automatic landing. Up until now, RTL_AUTOLAND was optional. I could set up a mission with automatic takeoff and landing, but the RTL behaviour was “loiter at Rally point” (or breach point), but now when I try to arm with a mission loaded I get this message: PreArm: DO_LAND_START set and RTL_AUTOLAND disable
This is the telemetry log. The problem happens about 85% in:
I checked the docs here, and I would say it’s pretty clear that RTL_AUTOLAND is supposed to be an option, not required. Was this intentional?
RTL_AUTOLAND is indeed optional, but in your log I see you have a DO_LAND_START mission item. The DO_LAND_START does not function at all without RTL_AUTOLAND enabled. We had an incident where a user setup a DO_LAND_START landing mission and didn’t set RTL_AUTOLAND. They were relying on the aircraft flying back via the DO_LAND_START sub-mission, and it didn’t. Due to the unusual flying location they lost the vehicle.
As it makes no sense to have a DO_LAND_START without having RTL_AUTOLAND set, I decided to add an arming check. If you have a DO_LAND_START in your mission (which you do in yours) then it will fail to arm with the message “DO_LAND_START set and RTL_AUTOLAND disabled”
To fix it either remove the DO_LAND_START, or if you really want it for some reason then disable mission checks in ARMING_CHECK.
Thanks @tridge. This then might be an issue. I didn’t explicitly add the DO_LAND_START, I just used the UI to drop on takeoff and landing waypoints as I have been doing recently during all my auto takeoff/landing experiments.
The QGC documentation states that when a Fixed Wing Landing is added this happens:
This pattern creates three mission items:
* `DO_LAND_START` - If you abort a landing it sends `DO_GO_AROUND` to the vehicle, which then causes the mission to return to this point and try to land again.
* `NAV_LOITER_TO_ALT` - Start point for landing
* `NAV_LAND` - End point for landing
So all landings created by QGC will have a DO_LAND_START, but would not necessarily want RTL_AUTOLAND. This also explains why you might want DO_LAND_START without RTL_AUTOLAND - so you can do a DO_GO_AROUND.
As @timtuxworth points out, DO_LAND_START is used for go-arounds. I often set up missions that way without using RLT_AUTOLAND. I think the check is a good idea, but maybe this needs to be the other way around, that if RTL_AUTOLAND is 1, then check for a DO_LAND_START.
@Allister@timtuxworth I’ve opened a PR to make this arming check specific to quadplanes. On quadplanes you can’t do a DO_GO_AROUND, so there is no use for DO_LAND_START without RTL_AUTOLAND.
That will still leave us with an annoyance for QGC auto-created missions, but I think we need to fix that in QGC.
Thanks for the feedback!
@Allister@timtuxworth I’m wondering if a better solution is to just suggest that users who want DO_LAND_START without any RTL_AUTOLAND set RTL_AUTOLAND to -1. That works now, and prevents the arming check failure.
I really do want this arming check as the vast majority of users who setup DO_LAND_START do want to use it for their landing sequence, and I’ve seen how forgetting to set RTL_AUTOLAND can lead to disaster and loss of an aircraft. The user sees the DO_LAND_START marker in the mission and assumes the plane will start the landing sequence there.
