Does anyone know how to set up SRXL receiver with Pixracer?
How do I connect it and how do I setup that with the RC channels?
In the Pixahawk hardware I see that there is DSM port (I think it is serial based port) but in Pixracer where should I connect the pins of the SRXL receiver and what should I do in order to get it to work?
Is it even possible?
I am not interested with PPM, I would like to use 16 channel multiplex receiver without using the PWM to PPM converter.
Also the SRXL receiver is small and can fit smaller size of a quadcopter.
Pixhawk supports MULTIPLEX SRXL version 1 and version 2 receivers using the SPKT/DSM input. PixRacer supports SPEKTRUM (PPM, SPEKTRUM & Sbus) on the RCIN input so it might work.
