hello everyone
on pixracer with arducopter serial 5 is connected to witch port ?
ser0 is usb
ser1 is tel1
ser2 is tel2
ser3 is gps
ser4 is frsky
ser5 ? the debug port?
thanks in advance for any help
hello everyone
ser0 is usb
ser1 is tel1
ser2 is tel2
ser3 is gps
ser4 is frsky
serial 6 isnt exposed in the firmware , is ther any way that i can use it ?
Why do you say this? I use serial6 (debug port) without problems.
in my params in arducopter 3.5.5 i have ser0 to ser 5
i want to have all the avalable usart ports at my displosal
You need a more recent release of ArduCopter
Parameters for SERIAL6 were added to master in June, 2018
Which version?
And what’s the type of the debug port (clearly isnt a jst gh😅)
Latest stable 3.6.9 is OK
All connector on Pixracer are JST GH except debug port that is JST SM06B
is there any magic to getting a gps to work on the debug port
Nope, just wire it up correctly and go. Be aware that the debug port can only deliver 50mA so you may need to power from somewhere else.
I tried repeatedly. Wired the GPS to a dedicated bec…no go no matter what i did.
So I gave up. Then read the FRsky port works as a gps port but it’s inverted. So I configed the port, made a new cable and bad da bing…second GPs.
So going to the field tomorrow to see if that helps with the glitching.
@andyp1per as always I appreciate your assistance.
configuring serial 4 (FrSky) as GPS port from within Mission Planner doesnt work on my PixR15 - inverting TX and SX doesnt change that - the module stays dark - it doesnt get power - did you alter the firmware to get this working? Ardurover 4.3beta. Theo
The Frsky port has inversion in hardware and you can’t invert it from software.
Pixracer has software controlled inversion of both SBUS and FrSky inputs
Thanks Mark didn’t realize that.
conversion of telemetry 2 port to SBUS works nicely and provides additional servo outputs - but I’m not sure which wire (VDD, TX, RX ground) needs to go where if I convert the FRsky port i to a UART port to hook up a 2nd GPS module… any advice is appreciated
