I struggle to connect to Pixhawk 4 via telemetry port using two HC12 modules.
I found two sources about this is possible:
Not a Pixhawk4 in all cases, but in principle it is possible.
Modules are in the same channel, baudrate 57600 and I can get serial connection on com ports with them successfully. But no success to get connection with Mission Planner.
Holybro telemetry radios connect with MP on both Telem1 and Telem2 serial ports. Boud rate 57600. Not sure if it is not possible to get connected with Pixhawk4 using HC12 modules, or if my parameters are not correct?
Any thoughts?
My parameters as per attachment.
standartiniai.param (18.2 KB)
