Hi guys, i need a clarification about how to right connect receiver to Pixhawk4 mini. I have an Holybro QAV250 development kit and R-XSR (access protocol) in sbus. I have connected it to RC IN port (via sbus) but sems that QAV not respond in the right way to trasmitter input (roll, yaw, …) . I read in
that RC IN should not be used to connect receiver but only PPM port that should support also SBUS.
I load ardupilot stack 4.03 latest.
Which is the correct reciver installation? Because there are some conflicting info !
@Mauro_Gatti,
Did you solve the problem? I have the same issue. I’ve tried the supplied XSR cable, and the PPM cable and still get “0 radio channels” from both ArduPilot and QGC.
-P
EDIT: Turns out the R-XSR to PPM cable I was using had the yellow wire connected to S.Port (since it is used to connect to the Transmitter for firmware updating), rather than SBUS-OUT. I moved the yellow wire over one pin (there’s only one way to go, since the other way is VCC) and now it works.
Hi Peter, i have solved the receiver issue on my Pix4min FC. The issue was related to PPM that is not correctly supported and it is better use S-Bus. So i will send soon some picture in order to show my wiring.
Any chance you have a pic or diagram of the wiring? I’ve got a PH4 mini and R-XSR but can’t get Mission Planner to see transmitter inputs. I’m following the docs to use SBUS but I think my wiring is wrong
No worries. I’m also interested in your SERIAL4 params. I’d ultimately like telemetry as well and I’m not sure if I need more hardware to achieve this. Thanks.
You have a wiring error.
The yellow wire needs to be connected to the SBUS OUT/CPPM pin of the receiver.
The blue S.Port wire at the Pixhawk end needs to be either disconnected entirely, or go to a serial port (possibly via a converter) for sending telemetry data from the Pixhawk to the reciever and on to the transmitter for use in Yaapu telemetry script.
Dear @dazonic ,
i confirm the suggestion of @xfacta .
You have to reverse fisically the cable and connect SBUS OUT/CPPM pin of the receiver.
Below the picture of my wire installation.
