I’m building a new quadcopter with two gps, optical flow sensor, osd, telemetry, 3 axis gimbal (storm32)
Each if this components use serial port, but pixhawk seems to haven’t more than 4 physical and virtual (according to parameters list) serial ports.
Could you say if its possible to multiplex serial ports or at least use the usb connector… ?
I think you could probably connect the optical flow and the OSD to the same port, since OSD is only receiving (at least mine is) and the optical flow is only transmitting, as long as the use the same protocol at the same baudrate.
I use minimosd, I see on minimosd arducopter wiki " To connect to APM 2.5 and 2.6, use a 5-pin splitter cable that allows the telemetry port to be connected to both a SiK Radio and the MinimOSD."
Each antenna will block some sky for the other. Space them apart to lower the angle.
Also, if there’s badly shielded active circuitry at the antenna, noise is generated. With your everyday 25x25 mm ceramic patch, reception gets ugly fast.
